Nearing 50K miles in 328xi -- What maintenence is needed?
10-20-2014, 12:26 PM | #1 |
358
Rep 3,447
Drives: 2018 X3 M40i
Hey everyone, thanks in advance for the replies. I'll be hitting 50k miles soon in my 328xi, and I was wondering what maintenance should be done, be it required or preventative. All suggestions are helpful!
10-20-2014, 05:46 PM | #2 | |
295
Rep 2,202
Nonetheless. If car is fine. Put gas in (don't be cheap either) and go. Do an oil change every 10k miles or so.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
10-20-2014, 07:23 PM | #3 |
325
Rep 5,370
I have a 2007 328xi and this is what I've done between 50-60K. Mostly just preventative
This is the approximate cost if you DIY'ed as far as I can remember Oil change - $40 Spark plugs - $55 (Advance Auto) Coolant flush - $30 Power steering ($60 since its Pentosin) Brake fluid flush - $40 Transfer case fluid - $60 with new plugs Microfilter - $20 (Advance Auto) Air filter - $40 (K&N Filter) Front Differential - $15 (one bottle of redline fluid) Rear Differential - $15 (one bottle of redline fluid) Transmission flush - $170 (parts from Tischer and fluid from Amazon) Drive Belt with new belt tensioner and idler pulley - $110 At 75K I'll do the transfer case again since the fluid was pitch black after 50K. Perhaps the water pump and thermostat too |
10-21-2014, 02:48 PM | #4 | |
358
Rep 3,447
10-21-2014, 10:35 PM | #6 |
358
Rep 3,447
