10-20-2014, 11:51 AM | #1 |
1509
Rep 5,089
F30 steering wheel pulls when braking
In the past week I notice, with hands off, the steering wheel pulls 10 degrees left or right, or right then left, while braking. It does not happen on all roads though. The car points straight otherwise, and tire wears are even at all corners, and across the whole width of each tire. I start noticing this after a 65 to 20 hard braking (tires squeaking) due to unexpected disabled vehicle at exit. I am not a track person, for a moment the car came alive at 10/10, is that how it is on the track? Maybe the brake pads need to be re-bedded? The pull does diminish gradually with miles.... BTW front brakes have 4500 miles left according on CBS.
10-20-2014, 12:26 PM | #2 | |
147
Rep 477
BTW, how can you tell that you have 4500 miles left on the brakes? Where in iDrive does it tell you that? |
10-20-2014, 12:31 PM | #3 |
Rep 205
Drives: 2014 335xi MSport
If I remember correctly its in vehicle info and then something like service.
It will be a list of all serviceable items and clicking on brakes will give you the mileage when they are due (33,000 in my case)
2014 335i xdrive MSport AW/CR, SAT, Prem, Tech, HK, DHP, MPPK, MPE, NWA, KMFDM, etc... |
10-20-2014, 12:42 PM | #4 |
147
Rep 477
Thanks I'll have to check that out. Alan, where in NJ are you? I grew up in North Bergen in Hudson County.
10-20-2014, 12:48 PM | #5 |
Rep 205
Oh I'm more central in Ocean County, on the shore in the Point/Brick area.
So a bit south of N Bergen.
10-20-2014, 12:54 PM | #6 | |
1509
Rep 5,089
Yes I will bring it to dealer to check. |
10-21-2014, 11:37 AM | #7 |
Now in the dark side !
65
Rep 1,136
Do you have a 328 w/o the M Sport brakes (floating 1 piston front calipers)?
If so, ask them to verify the front caliper guiding pins, it may be your issue.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
