10-17-2014, 03:13 PM | #1 |
56
Rep 359
Drives: 320d M-Sport, X1, 525d
Deactivating Traction Control / DSC in SPORT mode in a MY14 320d Luxury Line
How to deactivte the traction control / DSC in sports mode in a 2014 F30 320d Luxury Line? I'm aware of the fact that the Luxury Line F30s don't get the sports + mode but there has to be a way out to turn the traction / DSC off manually in Sports mode? As far as I remember the dealer told me I can do it by just holding the Traction button next to the gear lever but when I do it 'SPORT' seem to disappear from my MID and all it shows is Traction Control Activated or DSC off but I think the car goes to the Comfort mode by default as soon as you press the Traction control off button ?
10-17-2014, 05:01 PM | #2 | |
e92 - 335i
179
Rep 743
1 - Dynamic Stability Control This can not be turned off. Even with Sport+ Mode. This can only be turned off in comfort or eco modes 2 - Dynamic Traction Control This is what turns off in Sport+ mode only. This is how it works in my car, US spec. |
10-17-2014, 05:05 PM | #3 |
Rep 141
Dynamic Traction Control (DTC).
Dynamic Traction Control (DTC) allows more wheel slip and thus a more dynamic driving style with higher wheel traction and DSC controlling stability. A small amount of spin on the drive wheels improves traction when pulling off from a standstill in snow or on loose terrain. Dynamic Traction Control (DTC) is a sub-function of the Dynamic Stability Control (DSC) system that can be turned on and off. DTC has two major roles: to regulate traction and to enable sports-style driving while providing active stability control. When the drive wheels start losing traction the DSC automatically begins stabilisation measures. The Dynamic Stability Control system curbs the engine output and stops slip on the wheels. In exceptional situations, however, a small amount of wheel slip can be an advantage. When driving in deep snow, slush or on loose terrain a small amount of wheel spin improves traction. For these occasions, as well as those when the drivers want a sportier driving style, the DTC can be activated by pressing a button and this allows more slip and reduces the DSC’s curbing of the engine. The result: better traction and more thrust. The DTC also makes driving on snow and ice-free roads more dynamic. When activated, the DTC allows sporty drivers more room to manoeuvre around curves than the Dynamic Stability Control and even permits controlled drifts. The driver retains complete control over the vehicle in every situation and the Dynamic Stability Control’s stabilising measures remain active even when the DTC is activated. |
10-17-2014, 06:12 PM | #4 |
Rep 44
Press the dsc button to disable traction control, and hold it down for 10 seconds to disable stability control. On my sport line, I change to Sport + mode and then hold down the dsc button to disable all driver assists. I can confirm DTC and DSC are able to both be disabled, as I disabled them when doing autox.
10-17-2014, 07:35 PM | #5 | |
e92 - 335i
179
Rep 743
10-18-2014, 03:52 AM | #6 | ||
56
Rep 359
