Overheating- please help!!
10-16-2014, 02:30 PM | #1 |
Rep 163
I was driving last night and my car gave me the high engine temp notice followed by the overheated notice. I was about to get home after letting the car cool down.
Today, I tried to scan for codes but no codes popped up even after waiting for it to display the engine temperature warning. I'll attach photos from the reader. It shows issues with the cats, o2 sensors, and evap. I have catless downpipes on the car. The drive belt and fan function properly. I do however notice that the fan runs very fast now even when the oil temperature is relatively low. Also checked oil levels and they are fine. My guess is the Thermostat or Water pump but I don't want to proceed without confirmation. Please let me know if you have any ideas or suggestions. It is my daily driver so I would like to get the issue resolved as quickly as possible but I want to avoid the costs of taking it to my local dealer. Any help would be appreciated. Also, if you happen to have a Water pump for sale let me know! Last edited by bmwphill92; 10-16-2014 at 02:53 PM.. |
10-16-2014, 04:08 PM | #2 |
47
Rep 1,160
Happened to me and my buddies car. Randomly over heated happened to be the t-stat or wp. I ended up changing both due to them being attached to one another.
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
10-16-2014, 04:38 PM | #3 |
296
Rep 2,015
It's your water pump and/or Thermostat.
Best to change both... Cause the Tstat is 60ish. Your scanner is not reading BMW dcts. But your codes are there, or you cleared the codes before scanning. Common mistake. Do you DIY....? DN |
10-16-2014, 04:58 PM | #4 | |
Rep 163
I've done a good amount of diy on this car and am fairly familiar with it. However, I have never done a water pump on this or any other car. |
10-16-2014, 05:05 PM | #5 |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
Definitely the water pump. I had the same symptoms before I replaced mine a couple of weeks ago. Fan runs because the water pump is not running/cooling the engine. My Cobb AP3 didn't reveal any codes either.
Recommend changing the water pump, thermostat and the hose connecting the two and flushing the coolant at the same time. Part/coolant cost is around $500-600 online. The job is a PITA. You can do it yourself to save some bucks but IMO it's worth the extra $500-600 to let someone else do it. Good luck!
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
10-16-2014, 05:34 PM | #6 | |
Rep 163
If only I had an EXTRA $500-600 laying around.. None the less, thanks for the input. I just want to be 100% sure that it is in fact the water pump before acting on it. I will pick up the parts from my local BMW dealer once i verify and check all other possible faults including all the hoses and radiator. |
10-16-2014, 06:09 PM | #7 |
296
Rep 2,015
$411 in parts it cost me, delivered.
All OEM. Give me a bit, I will find the reseller(s) Do you have Ramps? Jack stands? I did it on Ramps. Look up BavAuto DIY 2 part videos. But you have to reset the codes before changing the pump. DN |
10-17-2014, 05:13 AM | #9 | |
296
Rep 2,015
The free version. It did for me. DN |
10-17-2014, 05:23 AM | #10 | |
17309
Rep 18,733
BMWlogger sounds like it is some sort of BMW scan tool. I said a BMW-specific scan tool will need to be used to read the water pump trouble codes because the codes are BMW-specific trouble codes. BMWlogger may also read OBDII codes, I don't know, but either way it is not strictly an OBDII scan tool. It looks like to me the OP used an OBDII scan tool to look for the water pump codes, which is why he didn't find any. I'm just trying to be clear on the difference between OBDII codes and manufacturer codes, the two are not the same even though manufacturers have manufacturer-specific codes that translate to the standardized OBDII code format. A lot of members on this forum do not understand the difference between OBDII and manufacturer codes. OBDII codes always illuminate the Service Engine Soon (SES) light. Manufacturer-specific codes (if not equivalent [translation of] to an OBDII code) do not throw the SES light. Last edited by Efthreeoh; 10-17-2014 at 05:29 AM.. |
10-17-2014, 05:24 AM | #11 |
296
Rep 2,015
Import parts depot:
On ebay they are higher price... But had a phone number listed, so I called them.... And he cut me a break for no ebay fees. Phone: 1-855-822-0479 crm@importpartsdepot.com Paid: $393.29 for Waterpump and TStat. Insist on BEHR brand TStat. Also, bolts are eBay item number: 3 of them: 161253701611. BMW part #: 11517602123 For $11.13. DN Sorry, just under $405 delivered. Please keep in mind: 1) OEM water pump bolts.... Can not be reused. 2) the new ones I listed are not aluminum and can be reused. 3) the eBay seller I listed for the water pump ships 32mm bolts (OEM Size).... But for new pump you need 26mm.... Hence why I just bought elsewhere. 4) Insist on BEHR brand TStat.... I had fitment and quality issues with Hamman brand. (both are OEM) DN |
10-17-2014, 05:39 AM | #12 |
17309
Rep 18,733
OP, the water pump is electric so it is not driven by a "fan belt". The radiator cooling fan is electric and controlled by the ECU, so if the car is over heating it will run more often and at high speed. The hoses on these cars are really robust, so I doubt that is the issue. If you are not an experienced DIY'er then I'd expect you to have some difficulty doing the repair yourself. You need a good set of tools and need plenty of clearance under the car to comfortably work on it. A reliable BMW independent repair shop should be able to scan the car and verify the pump trouble codes (have him show you while the car is hooked up) and replace the pump and t-stat for around $800. If you DIY it you'll save maybe $300 - $350 in labor, but if you really don't have the experience and tool set, you'll be saving yourself a big headache by have a professional make the repair for you.
99% of the time when these cars over heat, it is the water pump. The t-stat does not make the car over heat. The t-sat if faulty will throw the SES light, the pump doesn't. |
10-17-2014, 12:13 PM | #13 | |
Rep 163
Thank you all for you help. I will keep you posted as I will spending time to resolve this today. I will try to confirm the necessary repair with a BMW scan tool and at least get the parts ordered. |
