BMS Oil Catch Can
10-16-2014, 05:24 AM | #1 |
Rep 25
BMS Oil Catch Can
dears
am pushin a moded e92 and am wonderin how to empty the OCC without removing the hoses plz i need ur help and i wish if can add some photo thanks |
10-16-2014, 11:10 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Erm it's in two halves:
http://www.burgertuning.com/BMW_335_oil_catch_can.html just unscrew the cylinder from the top piece...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
10-16-2014, 12:43 PM | #3 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
It's possible to unscrew the lower half and snake it out with out detaching the upper half from the strut tower rod (I just did it last night). Keep in mind that to unscrew you twist counterclockwise as viewed from above.
10-21-2014, 06:14 PM | #4 |
289
Rep 864
Bms Occ Mod
Why not just run the hose to the OCC (to capture oil) then install a small air filter to the intave side so that it only breaths fresh air and thus eliminate the intake build-up. For the exit out of the BMS OCC just run a breather tube or hose with another non restrictive filter (very small) just to allow air to exit the occ and nothing back in. Would this work?
10-22-2014, 01:21 AM | #5 |
king of the hills
92
Rep 2,915
I ran a breather on mine for a while...there is a lot of blow by in this car and the breather filled up with oil enough that it started spewing a fine oily mist on the back side of the engine bay. I did this without a OCC though in between. I think this OCC works well enough that there is not a need to do such a setup (plus you will get some extra fumes into the ventilation system from the breather). There are also those who make the argument that some vacuum on the crank case ventilation system is a benefit, though no real numbers to back that up on this platform.
