E90 07 1.8i clutch judder..dealer says gearbox out to investigate...
10-15-2014, 03:53 PM | #1 |
Rep 10
Hi,
I have been getting clutch judder when pulling away in first, it's worse in the cold. Car has done 51000 miles full bmw service history. I have the extended warranty on the car. Took it to the dealer had a technician drive it and he agreed it's doing it but said that the clutch was not slipping but need to take gearbox out to investigate if it's covered by warranty etc. I had the gearbox changed 2 years ago and I would have thought they would have had a look at the clutch and the flywheel for any play or wear and tear, with the gearbox out ? Obviously worried about the cost but I do not ride the clutch etc. The other thing I wanted to get an opinion on is that I have had oil leaks for the past 5 years since I have had the car here is a list Rocker cover replaced 3 times Oil filter assembly Vacuum pump Both solenoid cams Would it be possible that oil as got in to the clutch but the technician did say the clutch was not slipping. Thanks for any help. |
10-16-2014, 12:46 AM | #2 |
886
Rep 9,097
There is no 1.8i car afaik.
Look for cdv removal diy and try that first. Oik leaks are very common on 318i and 320i. Having said that I rectified it with original parts and slight enhancement done to vacuum pump. If oil leaks reoccur, you need to concentrate on PCV. As they get blocked due to potentially short journeys and driving like a nanny. Change PCV, do more miles and drive in Italian style once a week. I had 320i car for 2.5 years. Its not the best engine but reasonable if you can rectify these issues. Good luck.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
