Oil level sensor problem? Help!
10-14-2014, 11:15 AM | #1 |
Rep 98
Ok soo yesterday out of no where my dash said i had below minimum oil .. Like way below .. I checked and founf a minor leak at the oil filter housing gasket .. Minor like no where near enough leakage to have it telling ke i lost like 4 qts .. Soo i put 2 qts in and check it again and now it says its full.. I had my turbos replaced about 2k ago soo they had to have done the oil with that job .. Atleast i hope soo..
10-14-2014, 11:44 AM | #2 |
Long Time Admirer, First Time Owner
18016
Rep 9,378
Which is why I ignore my oil warning until it stays on solid for at least 3 days. With a 7q full amount, being down 1q for 3 days isn't going to do significant damage, IMHO
10-14-2014, 01:50 PM | #3 |
181
Rep 1,681
The sensor told you it lost 4 quarts? Mine will go from showing mostly full to a warning for as little as a 1/2 quart if I'm idling on a decline. I can't imagine it would wait for that much loss before triggering.
10-14-2014, 05:57 PM | #4 |
17309
Rep 18,733
Oookay, so you are reading the oil level wrong. It only reports on the amount of the remaining 7th quart. The graph you see is not a measure of the entire quantity of 7 quarts of oil. You may have too much oil in the engine now.
10-14-2014, 06:03 PM | #5 | |
Rep 98
10-20-2014, 02:26 PM | #6 |
11
Rep 57
I recently did an oil change and getting a reading after was super frustrating. BMW in all of its infinite software wisdom felt the need to override everything on the dash with a low tire pressure alert. Well, all 4 of my TPMS sensors are bad so I get the alert every 2 seconds even if I cancel it which makes it impossible to get a oil reading because it takes so long. You would think that the oil level would be way more important then any other reading and another alert can't just cancel it.
Anyone know how to disable TPMS all together? |
