Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > My spark plugs after 100k miles
      10-13-2014, 11:50 AM   #1
mjleamy
Drives: 2006 330xi 6MT Monaco, Terra
I just changed my plugs after 99,810 miles. The DIY is great for getting this done, and it isn't even difficult. As much as BMW gets kicked around on these forums, I have to admit I am impressed with how these look after 100k (see pictures below). All 6 came out of the head looking about the same with no signs of burning oil or a poor mixture. I did crack the insulator on the first one, which is a lesson learned. They do not want to come out of the head after 100k without a little fight, and I should have been more careful on that first one. The cracked insulator left a bunch of ceramic particles in the spark plug hole, which I promptly sucked up with a vacuum cleaner. Since I had it out, I vacuumed every hole afterwards. It isn't a bad practice when you think about it as crap falls down there over time. Besides preventing debris in the cylinder, vacuuming gives a nice, clean surface for the plug to mate and seal with.
When you look at the old plugs, you can see the electrodes are badly worn. I checked the gap on one of them and it was 0.035 inches. When new these NGK plugs were 0.044 inches according to the DIY. The new Bosch plugs were pre-gapped to 0.04 inches (yes, this is supposed to be different from the original NGK). I checked each one and they were dead on.
So you probably are wondering if my 330xi is running any better after the plug change? To be honest, it ran flawlessly before the change, so I can't say there is much difference. Maybe it feels a little stronger and a tiny bit smoother, but it ran so smooth to begin with it is really impossible to tell.
Pictures (sorry, they are not the best):
All six, in order, with the cracked one coming from the front of the engine
first close-up
second close-up
      10-13-2014, 11:56 AM   #2
GoRomeo
GoRomeo's Avatar
964
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Thanks for sharing your experience about your plugs. I did this job about 2 yrs ago. Mine looked the same as yours. Are you replacing the coils too? I haven't but I am tempted to do it soon. I am at 117k miles.
      10-13-2014, 12:18 PM   #3
PichaDis11
PichaDis11's Avatar
295
Drives: E90 N52
Thanks for sharing as well. I am about to do this around this weekend to get rid of a misfire I've been getting every now and then.
Could you share on exactly what happened why the plug cracked?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      10-13-2014, 12:25 PM   #4
chazzz
chazzz's Avatar
116
Drives: 2018 Chrysler 300S
BMW Maintenance schedule shows that you need to change the plugs every 100k. I have to disagree with that. It's better to change the plugs every 40k to 50k. That'll keep your engine happy. Spark plugs aren't that expensive if you do-it-yourself.
I usually change the plugs in my Jeep every 25k or so, they're so cheap (Champion copper plugs, about $10 for a set of six plugs).
Platinum tipped spark plugs (in BMW) aren't designed to go for 100k.
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic.
      10-13-2014, 01:24 PM   #5
Rg21044
Rg21044's Avatar
25
Drives: 2007 BMW 335i Coupe
If you don't mind me asking, how much were the replacement plugs. Thanks.
      10-13-2014, 01:34 PM   #6
BMRSEB
90
Drives: M3 SR+
Mine looked about the same.. I changed mine at about 95K, not sure when they were changed so wanted to at least have a record of my own. Good thing is no oil residue, VCG in good shape.
      10-13-2014, 02:25 PM   #7
Blackhawk36
Blackhawk36's Avatar
30
Drives: 2007 335i 6MT No iDrive
They look like the center electrode is slightly shortened from erosion but not bad at all. The top one looks like there it is running rich (it has a black powdery coating appearance) or the combustion isn't complete. New plugs might fix that.
      10-13-2014, 02:52 PM   #8
mjleamy
I think it cracked because when I was torquing on it, I got sloppy and didn't keep the wrench centered on the plug. So I basically put bending stress on the insulator. Brittle materials like ceramics do not like to be put in tension
As for Blackhawk36's response about the one plug being a little more black, I agree that that plug shows the cylinder is running a little rich. I guess that could be a number of things, to include an injector not metering fuel quite right.
Rg21044 --- I just looked back on my Amazon order. I bought them directly from Amazon (not one of their other merchants) and the total for 6 was $55.80. I have Prime, so shipping was free. For comparison, Pelican has them for $11.75 per plug. Amazon is a lot better.
Last comment - IMHO, I wouldn't change these before 100k miles on an N52. There is no need as evidenced by looking at my old plugs and those from others. Exposing the cylinder to the outside world, yanking on the coils (and you do have to yank and crank on those suckers a little bit), and stressing underhood wiring and such more than necessary just isn't worth it. Besides, it takes some time to do that I would rather spend otherwise
      10-13-2014, 03:55 PM   #9
ctuna
1911
Drives: 325xi 06 wagon MT
Do you notice any difference in running?
Smoother or better response?
Where they pre gapped?
Mike Miller mentions that taking them out early is as much about
getting them out before they seize and looking for oil leaks around the
plugs is it is about replacing bad plugs early.
      10-13-2014, 05:24 PM   #10
Saintor
Saintor's Avatar
79
Drives: E90
My Bosch barely passed 65K and I had 2x misfires issues, then changed all of them. So yes, I would say change them at 60K miles (at last if they are Bosch ). I replaced my Bosch with NGK. I don't trust Bosch.
      10-13-2014, 05:32 PM   #11
mjleamy
Really cannot tell the difference in running, but it ran fine before the change. Yes, they were pregapped, but I checked each one. As I wrote above, they were dead on.
      10-13-2014, 05:53 PM   #12
pspressart
Drives: 2011 335i
When my car was at the dealer for the VANOS recall work, they also changed the spark plugs because I supposedly requested it (My SA really takes care of me). This was with 55k on the odometer. I have noticed a difference in the performance after the change.
      10-13-2014, 06:05 PM   #13
mjleamy
Note that 335i has an interval change of 45k from what I have read.
      10-13-2014, 06:10 PM   #14
FL335
85
Drives: 2009 335i
20-25k intervals w/ any tune on an n54. I could;t imagine not doing this basic stuff at reasonable intervals. OP, your car must hate you.
      10-13-2014, 06:25 PM   #15
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
The 325/328/330 recommends every 100k. NA engines spark plugs last way longer than turbo, especially with a tune.
On a side note to everyone, I'm assuming oil reside and smell from spark plugs mean the VCG needs to be replaced?
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      10-13-2014, 06:35 PM   #16
FL335
85
Drives: 2009 335i
Yeah BMW also recommends 15k for oil changes on he n54….GL w/ that. I had always found if you do the basics, cars last. Some of BMW's service intervals are "off"….
      10-13-2014, 06:43 PM   #17
Antetokounmpo
1552
For a stock N54, I would do what they recommend if I was under warranty since maintenance is free. BMW isn't going to tell customers to do it not frequent enough, they don't want their engines going bad too soon. Personally, I do mine every 5k or so but that's overkill, todays synthetic oils are so much better, some even recommend to change it as little as every 20k miles.
