10-11-2014, 05:35 PM | #1 |
26
Rep 38
M4 Battery Charging Via 12V Accessory Port?
I only use my M4 for weekend fun drives and the rest of the time it rests out of the elements in my garage. (My daily driver in the local Los Angeles traffic is a Sienna minivan.) I just bought a Ctek lithium battery charger to keep it topped and want to connect it in the simplest, easiest fashion without having to lift the hood each time I use it.
Does anyone know if I can use the cigarette lighter/accessory plug for this purpose? Thanks. |
10-23-2014, 08:44 PM | #2 |
Rep 16
I was thinking of the same thing about getting the CTEK LITHIUM US for my M4 since it will be garaged for 3 months. I called my local BMW service department and they told me that you could use the cigarette lighter/accessory plug for this purpose with the trickle charger they sold. I asked them if they had any Li Ion trickle charger and they told me they didn't even know that the M4 had a Li Ion battery, so I became weary of their recommendations.
I'm assuming that you bought this: http://smartercharger.com/products/b...ek-lithium-us/ Does the CTEK lithium battery charger you purchased came with a cigarette lighter/accessory plug? |
10-24-2014, 04:45 AM | #4 |
260
Rep 561
Drives: '23 M5 Comp
No, the newer BMWs do not have an active cigarette lighter/accessory receptacle when they are shut off. You need to connect it directly to the battery in the right side of the trunk.
I have the charger here, just waiting for my car that is on a boat right now... Best of luck! |
10-24-2014, 04:59 PM | #5 |
26
Rep 38
Yes, I bought the same charger that your link shows. However, I got it new on ebay for under $90, including shipping. It did not come with an accessory plug.
10-25-2014, 11:49 AM | #6 | |
1715
Rep 5,110
10-25-2014, 12:01 PM | #7 |
30
Rep 217
You can wire the charge points to have a pig tail so it sticks out of an area such as just behind the grill.
Not a hard thing to due even for the mechanically challenged, just make sure the exposed end (plug in) has some type of cap when not in use.
BMW Owner 2-3 & 4 Wheels
10-26-2014, 02:53 AM | #8 | |
Rep 16
I'm not so sure you'd want to directly connect it to the battery in the trunk since most BMW vehicles have an "Intelligent Battery Sensor" to prevent damage to the battery. Did some digging and I may go this route through the hood of the car to the windscreen. I'm not sure if the M4 has charging capability though the cigarette outlet which could be from inside the car or from talking to CTEK, an outlet in the trunk. Can someone confirm? In any case, CTEK does offer a cigarette outlet option for other chargers, not sure if it will work for the M4. http://smartercharger.com/products/a...nect-cig-plug/ I wish BMW manuals has more amplifying data on storing our vehicles.
2015 Mineral White M4 DCT
10-26-2014, 08:15 AM | #9 | |
30
Rep 217
10-26-2014, 08:24 AM | #10 |
Moderator
7512
Rep 19,368
The manual warns against charging from the accessory sockets. This may or may not be standard boilerplate liability coverage, but I would be reluctant to go against it without some reasonable assurance it can be safely ignored.
10-26-2014, 09:24 AM | #11 |
260
Rep 561
Drives: '23 M5 Comp
Has anyone tried to see if the alligator clips actually reach to both the (+) and (-) terminals under the hood? I have the CTEK charger, but my car is still on a boat coming to the US form my ED. I'm not sure that there is enough wire length on the alligator clip attachment to reach both terminals...
Thanks! BTW - Once and for all, you CAN'T use the accessory plugs inside the car. There is no power when the car is shut down... People keep asking the same question here... |
12-08-2014, 03:53 PM | #12 |
Rep 46
Drives: Mineral White. DCT M4, S1000RR
OK so I tend to "Cabin Up" my car during the winter months, when salt is on the road, and plug my Optimate 6 to the battery to keep it topped up and ready. I hadn't realised the M4 had a Lion battery until I went to connect my Optimate 6. So I am correct in assuming I cannot use the Optimate 6 and, if not can I use this?http://www.optimate.co.uk/optimate%20lithium.htm
12-08-2014, 03:55 PM | #13 |
Rep 46
Oh, and from what I have read it must be connected to the charging point under the bonnet (Hood) and not directly to the battery.
10-09-2015, 08:37 AM | #14 |
66
Rep 190
Yep, just picked mine up(the charger) and it says for batteries installed in a car connect the red to the battery pole and the black to the chassis away from battery and fuel pipe(assumes negatively earthed battery) so the under bonnet(hood) connections look like the only way.
10-09-2015, 10:44 AM | #15 | |
920
Rep 1,481
2015 Mineral Grey ///M4 6MT
10-09-2015, 10:50 AM | #16 |
2712
Rep 2,371
There are charge points under the hood. I've got the same CTEK charger, and I hardwired the pigtail to the charge points under the hood, with a fuse, even.
2015 Black Sapphire Metallic 6MT M4
11-15-2015, 08:08 PM | #17 | |
220
Rep 433
I just hooked mine up with the clips but would prefer to have the pigtail on there permanently for the convenience.
______________________________
?05 E46 M3 ZCP 6MT ?06 C55 AMG '97 911S 6MT |
11-15-2015, 08:27 PM | #18 | |
721
Rep 2,342
http://www.amazon.com/CTEK-56-261-Co...ZM5VC66NH82NAK Red goes to the Red Post, Black to the Metal post. Done. |
11-15-2015, 08:29 PM | #19 |
721
Rep 2,342
you CAN use this too:
http://www.amazon.com/Cigarette-Adap...ctek+cigarette This is pretty much what comes with the Mclaren Li-On Charger and I've used it in my F80. |
11-15-2015, 09:14 PM | #20 | ||
220
Rep 433
