10-09-2014, 08:38 PM | #1 |
99
Rep 700
Grinding Gear 1-2 Shift 335xi F30
I have a 2014 335xi M Sport with the 6 speed transmission. I have noticed recently that under heavy throttle the 1-2 shift has a grinding noise to it. I am familiar with the notorious notchyness of bmw transmissions but this is different. It only happens under heavy throttle though.
Yes I know how to drive manual. This is my 3rd 335 in stick. Any ideas on the issue? |
10-10-2014, 02:53 AM | #2 |
123
Rep 441
I suspect faulty synchromesh.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional | |
10-10-2014, 09:12 AM | #4 |
404
Rep 962
10-10-2014, 01:11 PM | #7 | |
56
Rep 278
Otherwise, yes I agree that you might have bad synchros. |
10-10-2014, 01:36 PM | #8 |
99
Rep 700
Wow that's terrible to hear it might not be a one off issue with mine.
Are you referring to the clutch delay valve? Im not sure if the new ones have these and if they are removable. Does anyone know? |
10-10-2014, 02:01 PM | #9 |
630
Rep 1,649
not sure if there is a CDV in an F30. been wondering that myself. Personally I think the 6MT in my F30 335 is the smoothest 3 series transmission i have had in a long time. my E90 335 was not great, E91 328 was better but still had issues 1-2, as did my E46 and E30 M3. I removed the CDV from the E90, E91, and E46 and ran Redline MTL in the box of all three. that seemed to help a bit.
10-10-2014, 03:00 PM | #10 | |
99
Rep 700
We will find out Monday for sure at the dealer. Let's hope they are able to fix it. |
10-10-2014, 03:08 PM | #11 |
2680
Rep 3,406
Not the first reported issue with the 6MT in these cars. There have been several who have had their transmissions replaced due to the 2nd gear synchro.
I've never had it grind, but my transmission simply doesn't want to downshift into 2nd sometimes. |
10-10-2014, 03:21 PM | #12 | |
99
Rep 700
Hoping the transmission does not need to be replaced. I would be out of the car for awhile. |
10-10-2014, 03:26 PM | #13 |
29
Rep 209
I have replaced syncros on my 260 getrag, they are $200 and a couple hours to replace once you have the trans off.
My 6MT never has issues, it seems downshifting to 1st is not as smooth but otherwise I thought the trans is great. If you suspect is the syncro, just double clutch. Pull the car out of gear, release the clutch, push it in and try shifting to the next gear. If it doesn't grind it's the syncro
1997 BMW M3 Single turbo 723whp GT42R 2000 BMW M5 - Daily 2014 BMW 335i xDrive 6spd loaded |
10-10-2014, 06:09 PM | #14 | |
99
Rep 700
10-11-2014, 11:05 AM | #15 |
30
Rep 254
Drives: E30 M3 & 325ic-F30 335i Xdrive
This happend to me at around 10k miles, needed the entire transmission replaced because my synchronization was off. Make an appointment asap, because the grinding will only get worse.
10-11-2014, 01:23 PM | #16 | |
99
Rep 700
Is it smooth from 1-2 shift now or still a little notchy? I only have 5,500 miles on it. |
08-10-2015, 07:34 AM | #17 |
648
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
OP - what was the final resolution of this issue? I text drove a 6MT 335xi a few weeks ago, and noticed the same grind on 1-2 shifts intermittently (told the dealership about it). I just assumed it was some issue with that car. But NOW I just drove home with my new (to me) 2014 335i 6MT, and both my son and I noticed it happening periodically, generally on a more aggressive 1-2 shift. It is more than a bit disconcerting.
p.s. Overall though, I think this 6MT is MUCH improved over my E90 330i!!!! Much to my relief.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
08-28-2015, 05:41 PM | #18 | |
648
Rep 1,476
Pretty disappointing in a car with 20,000 miles.
08-28-2015, 07:21 PM | #19 |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I can imagine. The bright side is it didn't let go on 48,001 miles, right?
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
08-28-2015, 08:14 PM | #20 | |
648
Rep 1,476
08-28-2015, 08:21 PM | #21 | ||
99
Rep 700
05-16-2016, 10:01 AM | #22 |
Rep 7
Drives: 2018 BMW M4 Comp package
grinding 1st to 2nd
This just starting doing the same thing on my 2014 335i - @ 30,000 miles. I have an appointment at the dealer to get this repaired under warranty.
