10-08-2014, 08:48 PM | #1 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
M235i P3 Vent Gauge (VIDI)
Hey all, I just want to share my experience with the P3 VIDI Gauge.
There are times when I would just like to see vital info, like oil and coolant temps, boost and ait on the fly. As you all know, we get none of that from BMW. I want to be able to see this information without having to install any unsightly boxes, have to perform modifications to my dash or invest a lot more money then I think it's worth. In comes the P3 VIDI gauge to fill that gap. It fits right into the OEM driver side vent and still allows you to direct airflow up or down, left or right. It was important to me to maintain some airflow from the vent as opposed to sacrificing one entire vent (as competitors products might do) as this is my daily driver. I was also interested only in numerical values, so the small display of the P3 was sufficient. It is a very easy installation. Simply undo plastic trim on the left of the dashboard, pop off the OEM vent, pop in the P3 gauge in it's place and tuck in the control box and all cables in behind it. Then just route the main connector down to the OBD2 port and plug in. Some initial config and you're good to go! P3 has solid videos showing all of this, exclusively on the M235i. Very happy thus far. It looks and feels OEM and more importantly it gives me those important metrics on the fly that I was looking for. Apart from reading the standard OBD2 port info (air intake temp, battery voltage, egt, oil temp, coolant temp, etc.) it will also read/clear codes, has a shift light function and even has a built-in 0-60 timer mode. Here are some pics and a few videos to give you a feel for the gauge. View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i Last edited by alz0rz; 10-15-2014 at 10:41 AM.. |
10-08-2014, 09:03 PM | #2 |
***** noob
1368
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
This is the V2 with oil temp?
I think a group buy its happening soon
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
10-08-2014, 09:07 PM | #3 |
What goes here?
450
Rep 1,356
Yes, this version supports oil temperature readouts. See video.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
10-10-2014, 06:36 PM | #6 |
***** noob
1368
Rep 10,479
Does the shift light work if your in another mode?
I know the v2 for f30s does it
2006 325xi (Sold)
10-10-2014, 08:05 PM | #7 |
What goes here?
450
Rep 1,356
Yes, the shift indicator works regardless of the display you are currently in. I have it set at 5400 because by the time I see it and act I'm probably already at 5700'ish.
2019 G30 M550i
10-17-2014, 10:09 AM | #9 |
What goes here?
450
Rep 1,356
No but it has a dimmer function that'll lower the brightness and that has a better color match. You can wire this (included) so it does it passively or you can hit the button and do it yourself on demand.
2019 G30 M550i
10-18-2014, 12:28 PM | #10 |
839
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
For anyone who is interested, there is a group buy in progress for this. Check the other threads in this category for the info.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
10-18-2014, 04:20 PM | #11 | |
What goes here?
450
Rep 1,356
No complaints on this unit at this time after a few weeks of use.
2019 G30 M550i
10-29-2014, 01:13 PM | #13 |
What goes here?
450
Rep 1,356
Stock, the highest I've seen is 10.0.
10-30-2014, 04:33 PM | #15 |
454
Rep 986
Got the P3 kit today, which came pre-installed in a vent. So installation took about 30 minutes or less. I am going to hook up the dimmer wire, but I didn't have time to rip apart more stuff. I was told we can use the RED/GRAY wire at the trunk release in the kick panel. You will need one red inline t-tap connector that you can use the included 1/4" male spade connector!
10-31-2014, 04:04 PM | #16 | |
415
Rep 860
I will be doing that, too - would be silly not to, I think. Hahaha - just as I was typing this, I got the notification that my gauge has shipped It'll be a great mod. It's funny - I'm more excited about seeing what I can do for mods on this car than my other car. Might have something to do with the cost of modding them comparatively, but nonetheless, it's fun as hell with the Bimmer
"Anima sana in corpore sano"
