10-08-2014, 02:35 PM | #1 |
454
Rep 986
Testing out Oil Temperature Gauge
I am testing this ScanGuage II from a company called Linear Logic. They have a custom firmware that has a few extra readouts for the MINI series, and as you know BMW owns Mini. They gave it to me for a week to play with it and if it has what I need I could purchase it or return it for a full refund.
I was specifically looking for Oil Temperature, Oil Pressure, and Coolant Temperature. So far the results are looking good, and it's a quick and easy way to get these gauges. I'll post pictures shortly! |
10-08-2014, 02:56 PM | #2 |
454
Rep 986
ScanGauge 2 on BMW m235i
Here are some pictures for you guys to check out. The going rate for this is $159.99, if you like it though you should order directly through them since they have to load a custom MINI firmware on it.
http://www.scangauge.com/about/contact-us/ |
10-08-2014, 04:05 PM | #3 |
454
Rep 986
EOT - Engine Oil Temperature (Degrees Fahrenheit)
OPR - Engine Oil Pressure (PSI) GAL - Fuel Tank Level (Gallons) FLT - Fuel Temperature (Degrees Fahrenheit) PSI - Fuel Rail Pressure (PSI) FAN - Electric Fan (%) A/F - Air To Fuel Ratio |
10-08-2014, 05:24 PM | #4 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Looks cheap but whatever works right...how much?
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
10-08-2014, 07:02 PM | #5 |
454
Rep 986
ha whatever floats your boat. read the rest of the post, price is there.
Go get a p3cars, Akron DGA vent setup, or if your bottomless wallet supports it get a 3ddesigns 3 gauge pod, and Stack Pro 52mm stepper motor gauges. Since my car is a driver car, I won't sacrifice a vent if you really are tracking your car all day, then get a real gauge setup. This is for curiosity, and you can program it for other gauges if you put the effort in. I can remove it and not have to worry about BMW bitching about voiding the warranty. |
10-08-2014, 07:57 PM | #6 |
***** noob
1370
Rep 10,479
just stating my humble opinion
Whatever works You can also use a phone app to get that stuff for an external setup like this. This look like something from 1980s
2006 325xi (Sold)
10-08-2014, 08:10 PM | #7 |
454
Rep 986
Yes you can get a Bluetooth ODBII ELM327 adapter, and the Torque App.
IMHO, it does the job, and provides what the manufacturer should have What are you using for Oil Temperature ? |
10-08-2014, 08:22 PM | #8 | |
***** noob
1370
Rep 10,479
Again, whatever works..dont have to be fancy but I do like the p3 setup If this was like $80..i'll hit it but not for $100+
2006 325xi (Sold)
10-08-2014, 08:59 PM | #9 |
What goes here?
452
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
10-09-2014, 12:57 PM | #11 |
Loves his G20
265
Rep 2,507
It still baffles me that BMW can't just whip up a quick software fix where at a minimum the oil temp would show on the odometer/trip computer. Especially since it's an MPV which is like 7/10ths an M car.
2020 330ix-Msport Past- 2013 135i 2011 135i |
