The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Tmap Sensor maxed out
      09-29-2014, 08:34 PM   #1
StatiX
Indonesia
Drives: 2010 335i
Question Tmap Sensor maxed out
Hellow guys ...
I just installed the VTT stage 2 turbo ... but un tuned yet ... will be tuned by PFT ... now the problem is when i took a cobb data log ... the log shows that i am running flat at 21.7 psi ... so i checked my meth kit boost gauge to see how high am i running ... it shows 24 and 26 psi ... which i think above our sensor are able to read ...
so, are there any aftermarket tmap sensor ??? i have been searching everywhere and i got nothing ... maybe any of you have any information where can i get an after market tmap sensor that can read up to 30 psi ??
before Dzeno cut my psi lower .. hahahahaha...
thanks in advance ... :P
      09-29-2014, 09:45 PM   #2
Curare86
57
Drives: 135i
My understanding is this cannot be done with cobb alone. Either switch to jb4 with n20 tmap sensor, or standalone ecu like aem ems. Sure ptf could give more info
      09-29-2014, 09:55 PM   #3
StatiX
Indonesia
Drives: 2010 335i
so there is no aftermarket sensor for n55 ?? none created yet ??
ok then .. i will ask Dzeno .. i want to know what other method he can tune beside the cobb ... i love his aggressive tune ... hahahaha...
      09-30-2014, 02:24 AM   #4
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
PTF don't support stacking on the N55 at the moment.
If you want to switch to the JB4 then you can use the sensor from the N20 engine which reads up to 3.5bar.
But I'm sure I remember Terry saying he wasn't getting much extra power going over 21 psi.
      09-30-2014, 03:52 AM   #5
StatiX
Indonesia
Drives: 2010 335i
hmm... i just got my self a n20 sensor that i can try on ... so its not actually a plug and play ???
oh well... i will see how is the 1st revision from PTF and see how it goes ...
so ... all n55 tuner are only running at max of 21 psi ??
      09-30-2014, 08:46 AM   #6
tke344
38
Drives: f15 X5 50i
The N20 sensor is scaled differently and the Cobb can't adjust the table. Not sure what the actual numbers are but lets say the stock tmap 5v = 21PSI, on the n20 sensor 5v = 35psi The JB4 can re-scale the voltage / PSI
      10-01-2014, 03:24 AM   #7
Nugget
Nugget's Avatar
650
Not plug and play, you'll need a JB4 with Flex fuel wires, N20 sensor adapter and USB cable.
More info here
http://www.n54tech.com/forums/showthread.php?t=24788
      10-08-2014, 02:26 AM   #8
StatiX
Indonesia
Drives: 2010 335i
sorry i just read this ..
thx anyway .. i will see how PFT do with 21 psi then ..
thanks for the input
More info here
      10-08-2014, 02:27 AM   #9
StatiX
Indonesia
Drives: 2010 335i
this will be a hastle for tuning i guess... so , basically everybody is restricting their n55 to 21 psi for now ??
      10-08-2014, 04:49 AM   #10
Curare86
57
Drives: 135i
Not for long!!
      10-08-2014, 09:36 AM   #11
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Not for long!!
Explain?
      10-11-2014, 04:01 AM   #12
Curare86
57
Drives: 135i
Originally Posted by Darkhold View Post
Explain?
well jb4 can already use the n20 sensor to upscale boost.
Now that the PTF guys have brought out their port injection fuelling etc, my understanding is that running that with AEM or other EMS will allow increased boost limits also. Thats why I bought this
      10-11-2014, 08:49 AM   #13
turbo_chris
51
Drives: 11 E90 335D, 13 X5D
More info here
You may not need a adapter for the N20 sensor. There are two different connectors that came on the N55's for tmap. Look on Terry's site for the jb4 where it says to determine if you need harness A or B. The 3.5bar N20 TMAP was P&P on my E90.
11 335D - BPC stage 2.5
13 X5D - Family hauler
01 Cummins 3500 - 1100 torques
      10-12-2014, 03:48 PM   #14
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
Nice! I wonder what you get out of it.
Tags
akrapovic, pft, vishnu, vtt
