ViSRacing Bmw 3 Series E90 4Dr M3 Style Carbon Fiber Hood, 2006-2008
09-27-2014, 09:35 PM | #1 |
Rep 8
My son bought this hood, but before installing someone ran into him and the car was totaled. The hood is still in the plastic and connect to the wood that it was shipped on. I threw the box out, but everything else is there. We replace the car with a 2005 M3. We would trade for thing pertaining to this car only trade value $800. I bought this hood on ebay you can see pictures of the hood there. Any questions you can reach me at 443-758-2242 Thanks, Charlie 2006-2008 Bmw 3 Series E90 4Dr M3 Style Carbon Fiber Hood SKU: 06BME904DM3-010C Material: Carbon Fiber This part will fit: 2006, 2007, 2008 BMW 3 Series E90 2006-2008 Bmw 3 Series E90 4Dr M3 Style Carbon Fiber Hood This Hood is made out of Carbon Fiber and will fit 2006, 2007, 2008 BMW 3 Series E90 All ViS Carbon Fiber Hoods are manufactured using a two-part construction design. The top layer utilizes a 100% ISO certified, Grade A carbon fiber material. The carbon fiber material is bonded to the hood using a high grade epoxy resin, and then finished with an ultra-clear (Poly Shield), UV-protective polyurethane coating to ensure a high gloss finish. Marrying aesthetics and functions, ViS pioneered the use of one-piece, smooth underside shell which complements the fine finish on top, and at the same time strengthens the product's structural integrity. The edges of each trunk are meticulously smoothed by hands to insure high-quality finish all around. The result is a carbon product that is unparalleled and excels above all else in quality, durability, and aesthetics. Any of our carbon fiber products (or CF / C.F. for short), would be lighter than your metal OEM parts by about 50%. Along with the customized look, our vented hoods not only provide aesthetics, but the vents help to bring cool air in to reduce and extract the ambient heat in your engine bay. ViS Carbon Fiber Hoods are made from the finest carbon fiber available. Each hood is protected with a UV coating which allows the hood to hold its high gloss finish. All our carbon fiber hoods are Grade A and above. ViS Carbon Fiber Hoods have a tight carbon weave, rolled edges, and one piece undersiding. Make sure when purchasing a ViS hood, look for the ViS Authenticity Badge. Hood pins are required. Intended for OFF ROAD use only. Hood only, no hardware included. This is Aftermarket Replacement Carbon Fiber Hood. Due to the unknown nature of the intended uses of these products, hood pins are required. These products are intended for off-road use only, unless your local and state laws state otherwise. |
11-02-2014, 07:41 PM | #2 |
Sponge
Rep 55
I interest in hood. Can I pay $2000 to ensure prompt delivery? If yes, please send check of $1000 so I can wire funds to my check acount and send pays. PM for details, I am promise this not a scam.
Blessings, Frank
07 E90 335xi / Jet Black / Sport, Premium, Cold Weather Packages / 50% rear tint / CDV delete / MTEC 7000K AE / 6000K Xenon fogs / Beyern Rapp 18x8.5 Gloss Black w/ Mirror Cut Lip square / BMS DCI / BMS OCC / de-badged / B&W roundels / more mods planned....
11-03-2014, 06:09 AM | #3 | |
2203
Rep 3,338
Drives: X5 & E90 WTCC Racecar (SOLD)
Buyer didn't mention it, but his father is also a Nigerian king. Legit dude. |
11-03-2014, 08:04 PM | #4 |
101
Rep 912
how much?
Check out my built thread of my white beauty! http://www.e90post.com/forums/showthread.php?t=1045460
Follow me on Instagram! l_gomez1215 |
Tags |
bmw 335i hood m3 |
