2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions How to deactivate active engine sound?
      09-23-2014, 11:24 PM   #1
drp90210
11
Drives: M235i
I have read two links suggesting the "active sound" engine noise that is artificially amplified into the M235i can be deactivated. Here they are:
http://www.bimmerfest.com/forums/sho...d.php?t=672496
http://f10.m5post.com/forums/showthread.php?t=983411
Has anyone ever tried one of these methods on a 235i? Would appreciate some guidance as I find the noise very annoying. Thanks,
      09-23-2014, 11:26 PM   #2
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
ya you need to code this
ASD 3000 Model Range F022 F020/F021
      09-23-2014, 11:30 PM   #3
drp90210
11
Drives: M235i
Thanks! Will a dealer do this? I am a bit challenged when it comes to this.
      09-23-2014, 11:32 PM   #4
pikcachu
pikcachu's Avatar
1399
most likely not....
http://www.2addicts.com/forums/showthread.php?t=1010377
      09-24-2014, 09:51 AM   #5
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
pikcachu, I see that you're one of the experts on the "coding" area. Would you mind sharing with me if disabling the air conditioning from turning on automatically when I start the car is possible with a code? Thanks for your reply.
      09-24-2014, 10:38 AM   #6
pikcachu
pikcachu's Avatar
1399
yes...
Air conditioning always remember air recirculating IHKA 3003 MEMORY_UMLUFT aktiv
AC off on startup IHKA 3003 MEMORY_OFF nitch_activ
      09-29-2014, 02:37 PM   #7
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
I discovered that coding F020/F021 (within ASD 3000 Model Range) will not work to completely disable ASD. I coded F003 and was successful in completely disabling ASD.
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      10-02-2014, 12:46 AM   #8
drp90210
11
Drives: M235i
Coding person in LA?
Does anyone know a reputable coding specialist in Los Angeles? I am to chicken to try the coding tips myself but would very much like to deactivate the active engine sound.
      10-11-2014, 12:23 PM   #9
bman6074
103
Drives: 14 M235i and 07 Lotus Exige S
Do you have a picture or more detail to what you coded? I am not seeing F003 in ASD
      10-11-2014, 08:20 PM   #10
alz0rz
What goes here?
alz0rz's Avatar
450
Aye, sorry yes I just looked again and noticed that I actually did F006.
2019 G30 M550i
GBNF:
      10-19-2014, 07:09 PM   #11
dan84
Drives: 2011 Tundra SR5 CrewMax 5.7L
I'm seeing conflicting answers to my question on the forums. Does the M235i have the pre-recorded engine sound or a microphone somewhere in the driveline that is piped through the speakers (like the M3/M4)?
      11-04-2014, 01:45 PM   #12
bman6074
103
Thanks for the photo. I finally got around to this change and I have to say it is BY FAR the BEST change yet. I feel more connected with the car now. Hearing the rawness of the exhaust and engine sounds instead of the fake active sound.
      11-04-2014, 02:27 PM   #13
alz0rz
What goes here?
alz0rz's Avatar
450
So can you confirm that you did in fact notice it being COMPLETELY off?
2019 G30 M550i
GBNF:
      11-04-2014, 05:51 PM   #14
bman6074
103
Yes from what I hear it is completely off. Here is a video I did to show what it sounds when active sound is disabled using the coding in the screenshot above.
Here is a M235i with active sound enabled for comparison
      11-05-2014, 08:39 AM   #15
bimmerbuff
Slightly Less Obsessed
bimmerbuff's Avatar
26
Drives: Between BMWs
Good question. I could never find a clear answer on that.
      01-15-2015, 02:00 AM   #16
hyperzulu
hyperzulu's Avatar
701
Drives: 2015 M235i
Can you clarify? Completely disable, as in you still heard some ASD but to a lesser degree? I just modified to f020/f021 and it sounds fully off to me.
      01-15-2015, 02:17 PM   #17
fkacct
Drives: 550i M-Sport --> 228i M-Sport
Can someone confirm if 228i models have Active Sound? Can't seem to find a solid answer to this....
      01-15-2015, 07:07 PM   #18
MikeG12
65
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
Yes, it does, and I love it!
      01-15-2015, 08:35 PM   #19
alz0rz
What goes here?
alz0rz's Avatar
450
Yes, I noticed when you modify to f020/f021, while the ASD is reduced considerably, that there is still an undertone that may be the sound that is 'programmed' for the F20/F21. Try changing it to what I suggest and I guarantee you'll hear a difference, I did.
2019 G30 M550i
GBNF:
      01-16-2015, 02:06 AM   #20
fkacct
Thanks, I'll try shutting it off this weekend and report back. It must be a real subtle effect.
      01-16-2015, 01:23 PM   #21
hyperzulu
hyperzulu's Avatar
701
Drives: 2015 M235i
Thanks. I shut it off completely and then turned it back on after a day of driving with it. At least now I know how quiet the exhaust is... my 335is was louder and it was perfect. This muffler just needs a bit of packing removed. A different downpipe wouldn't hurt either, but the overruns sound cool already.
      01-17-2015, 06:27 PM   #22
fkacct
Got around to shutting off the Active Sound on my 228i using the F006 code as mentioned here (didn't bother trying F020/F021). I noticed a significant difference in engine noise after 4500 RPM. The car is naturally very quiet after 4500 rpm but Active Sound adds a nice bassy undertone. Active Sound was much less noticeable below 4500 RPM. I don't really like the fact that BMW has chosen this path. Really messes with my purist idealism....but the car definitely sounds better with Active Noise ON. I wish they just tuned the exhaust and made it sound nicer without this extra gimmick. I guess the advantage here may be that cars can be made more quiet (pack up that muffler like they did on this car).....and still make the car enjoyable to drive. This may not mean much I guess in a rural area with few cars but would maybe make a difference in the amount of car noise pollution in a large city with lots of cars...
2addicts
