FMIC Help Options for OEM fit
09-23-2014, 07:13 PM | #1 |
101
Rep 846
Need some help on my Options for a Front Mount for my 2007 E92 335i.
Other then the Forge and Mishimoto what are my Options on a front mount that is a plug and play unit? Looking for something without any Cutting and will use all OEM Piping. I know the two I have listed do this but are there any others I don't know of? Can you post up links of any. Thank you all for your help. |
09-23-2014, 07:26 PM | #4 |
101
Rep 846
09-23-2014, 08:13 PM | #5 |
38
Rep 753
650 is expensive. But the cheapest you can find a mishimoto is 550 (topgesrsolutions) Nobody has ever done a comparison between the 2. The benefit of the Wagner being it is stepped. I'm on the same boat your in I want to keep it as stock looking as possible.
09-23-2014, 08:19 PM | #6 | |
101
Rep 846
Forge $1100 Mishimoto $597 Wagner Tuning EVO1 $650 |
09-23-2014, 08:27 PM | #7 |
2033
Rep 8,339
If the VRSF is like my 7" it uses it's own pipes but the stock pipes are still good and you can reverse the install without getting new ones. So if you're worried about reversing to stock you can.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
09-23-2014, 09:59 PM | #8 |
38
Rep 753
You still have to cut the accordion type hose on the passenger side though.
09-23-2014, 10:01 PM | #10 |
88
Rep 1,039
With the 07 you need to go Wagner or helix for the best fitment. Pre lci cars the vrsf hangs low and there will be a slight gap (unless they fixed it)
09-24-2014, 08:51 AM | #11 |
2095
Rep 43,350
The stock connectors neck down to less than 2". They're a huge restriction and have proven to leak above stock boost levels.
You can absolutely put the car back to stock when you're done with the FMIC, you don't cut the connectors off, you remove the clamp that holds the connectors in place. If you need to re-install the intercooler you can easily purchase two BMW worm gear clamps to replace the factory ones that were removed. There's no "gap" or low hanging on any model unless the car is missing it's weather stripping or it was improperly installed. The 5" stepped unit covers the entire open area as well. |
09-24-2014, 09:05 AM | #12 |
100
Rep 1,040
I have the ER and its not much more noticeable in the front than the stock aside from it being a little more shiny. I understand maybe not wanting to trim the radiator shroud, but wanting to have smaller, more restrictive stock connections on the intercooler and willing to pay more for less performance just doesn't make sense to me. You don't have to "cut" the accordion hose, you just break the one time use clamp and you can get another one of those... You can also get another accordion hose. VRFS 5" stepped plus brand new accordion hose would be less than those more restrictive cores.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
09-24-2014, 09:38 AM | #13 | |
38
Rep 753
09-24-2014, 10:22 AM | #14 | |
100
Rep 1,040
No, I'm saying you can simply get another accordion hose or just another clamp if you wanted to return your car to 100% factory specs. I am not understanding the desire to run restrictive hardware on a part designed to increase flow and cooling especially when it is closing the door to more efficient cores such as the VRSF stepped in return for, at bare minimum, an additional $200.
09-24-2014, 10:28 AM | #15 | |
38
Rep 753
09-24-2014, 10:34 AM | #16 |
The Wolf
250
Rep 988
Drives: stuff
but the stock clamp is NOT a worm style clamp, it would be obvious it was removed/replaced
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
09-24-2014, 10:45 AM | #17 |
100
Rep 1,040
You can purchase the stock clamps... I don't know why this is an issue. I doubt a warranty would be denied if your intercooler clamp looked a little too clean. If the type of clamps you're using will encourage you to buy a poorer performing, more expensive intercooler, then why bother modifying your car in the first place? Am I lost in a classic corvette forum?
09-24-2014, 10:50 AM | #18 | |
The Wolf
250
Rep 988
Drives: stuff
09-24-2014, 11:29 AM | #19 | |
Rep 277
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
09-24-2014, 12:49 PM | #20 |
101
Rep 846
Well not to be rude or offend you or anyone else as to why I want to do this in this way is in the end it's my car my thinking and it's how I want to do it. To put it plane and simple I just want something a bit more efishent then stock not looking for every last 1/2 hp just somewhat better then stock if I want fast I'll get on my Ducati. But thank you all for the input.
09-24-2014, 01:01 PM | #21 | |
100
Rep 1,040
As for OP, you are free to do whatever you wish with your car, but you come to a forum looking for advice, so people with the experience you are looking for chime in with their advice. May not always be what you want to hear, but at the end of the day, do what you want with your car. If you want to spend $1,000 on a restrictive intercooler, then by all means... If you have silly requirements that don't make any sense and don't wish to elaborate as to why you need restrictive OEM connections on an aftermarket intercooler, just expect people to question your logic.
09-24-2014, 01:27 PM | #22 | |
101
Rep 846
Like I said its my parogative and I did not ask what was the best or has the most HP numbers I was very spasific in my title and what I was looking for in my post and title, I don't want to know the best flowing FMIC just plane and simple "what FMIC's work and mate up with OEM lines" can't make it any simpler if it dose not fit that criteria then it's not something I want to consider. But Thank you |
