09-22-2014, 04:23 PM | #1 |
71
Rep 338
Trackday with i8
Featured on BIMMERPOST.com i8 didn't offer any surprises at track. The cars is fast and balance extremely good. Suspension is FAR better than E92M3 w/KW Clubsport and even better than F430. I didn't push car to the limits but still had couple of faster laps. Grip was good and I think this chassis can take much higher hp than i8 can offer. I felt a slight lack of hp in certain sections, but that wasn't due lack of power but instead of high absorption capability of the construction. I think i8 could accomodate 500-600 hp without any problem. I have a video about laps, I'll drop it later on. Herewith couple of photos. Please note rear section of the car - you can really see aerodynamics of the package from these 600 mm telephotos. There's unique air channeling around rear tyres that is hard to understand while inspecting the car at close proximity. And tyres - yes, you can't track them. 3 faster laps without any serious braking and they are clearly melted. Compound may not be very soft itself but these tyres can't stand track heat cycles nearly at all. I have to seek better tyres for next season in order to drive even shots stints. In practise you can't do track days at all with i8 OEM tyres. Edit: video added
i8 2014 (PI, Protonic Blue), X1 25i 2016. Gone F30 320i xDrive 2013, E84 X1 23d 2010, E60 530 xdA 2006, E92M3 2008, R53 Mini Cooper S 2006, F430 F1 2008
09-23-2014, 04:39 PM | #2 |
621
Rep 1,646
Thanks for sharing this info. Very interesting, and disappointing, about the tyres. It will be good to see which better, sticky, tyres we can find to replace the OEM ones with.
How did you find the understeer? Did you have any success in getting it to oversteer? Any ability to adjust attitude via the throttle? How did the brakes stand up to repeated hard use? Thanks again |
09-24-2014, 01:39 PM | #3 | |
71
Rep 338
About understeer, yes, couple of times I noted some understeer, not much though. I think you can control it using throttle quite well. The chassis is so well balanced that it's pure joy to track this car. Rolling is almost non-existent and i8 is accurately under control all the time. Several similar impressions seen in 991 Carrera S which is also very easy to drive at track.
09-24-2014, 03:55 PM | #4 |
621
Rep 1,646
Thank you again for the info. Pity you did not get the chance to try out the car for longer.
I had planned to take mine to Brands Hatch when I received it, but am not so sure now. Might be better to do that when I select better tyres for it. Even my cut slick tyres on my Lotus have some "melting", and those are designed for the track, and are on a car half the weight of the i8. But they do tolerate being driven hard on track for hours on end, despite the heat. That is with severe high G (1.3G+) cornering lap after lap, and severe on limit braking though. I cannot imagine the i8's tyres being designed to cope with such heat cycling, or even just those kinds of temperatures. Looks like we need to find higher performance rubber |
09-24-2014, 04:05 PM | #5 |
71
Rep 338
I'd suggest you to wait until we find a good solution for track tyres. Or, in case you still try, go _very_ carefully 2-3 laps and check tyres then.
I tried to fix video, but Youtube compressed it too much. I'll try again tomorrow. You'll get some impressions then
09-27-2014, 06:17 AM | #6 |
71
Rep 338
I went through Pilot Supersport catalogue and they have 225 & 245 size tyres available for R20 wheels. Fit pretty well for i8. PSS is not a track tyre but might be reasonable compromise for i8 trackdays.
09-27-2014, 10:35 PM | #7 |
20
Rep 146
Drives: i8 Protonic Blue/Pure Impulse/
Garage List 2015 Ford/Mustang G ... [0.00]
2014 BMW/i8 [0.00] 2015 Jeep/Rubicon U ... [0.00] 1967 Chev 427 Corvette [0.00] |
Tires
Thanks Pitkis, I wondered if anyone had studied the Pilot SS fitments. (I've just been too lazy, so far!) I've had very good luck with them on previous cars like a few R8's, F430 and Ford GT. All for street use.
Put a set of Mich Pilot A/S sports on a Z8 and they were great road tires for that more sedate sports cruiser too. Hoping new rubber will help cure some of the real or perceived ill's on the i8. Love the pix and feedback on your car. Mine will be an identical sister, when it arrives. |
09-27-2014, 10:50 PM | #8 |
95
Rep 678
Drives: E30M3, E39M5, SLSAMG, RRS SVR
Garage List 2015 Range Rover Sp ... [0.00]
'03 BMW M5 [0.00] '88 BMW M3 [0.00] '84 Toyota Corolla ... [0.00] '14 Ford Fiesta ST [0.00] '12 Mercedes SLS AMG [9.83] |
I love the supersports on my SLS and E39 M5. Best riding tire with the least road noise and they are still decent on track. Depending on how I end up driving the i8 I may choose them when it's time to replace the OEM.
09-28-2014, 03:04 AM | #10 | |
71
Rep 338
I hope you get your own soon! Great to see we have identical cars
09-29-2014, 06:04 PM | #11 |
10817
Rep 27,600
def enjoying the ride! thats awesome to see.
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
09-29-2014, 06:06 PM | #12 |
398
Rep 2,181
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
In what way is the suspension far better than the other two?
09-29-2014, 06:16 PM | #13 |
504
Rep 3,446
Low rolling resistance tires are not for the track.
See my photography at http://ronscubadiver.wordpress.com
09-29-2014, 06:17 PM | #14 |
1309
Rep 2,787
Did you lose electric power as quickly as Motor Trend did in Best Driver's Car test? They lost electric power by lap 3 at Laguna Seca.
Their lap times were 6 secs different from lap 1 to lap 3. |
09-29-2014, 08:07 PM | #20 |
3161
Rep 9,134
09-29-2014, 09:04 PM | #21 |
373
Rep 1,698
I wanted to like the i8, but for $140k+ it just doesn't have the performance to back its looks (which I think are just "ok")... hence I own an R8. The R8 was more money, but it offers actual supercar performance to match its good looks. I feel like the i8 is more of a science project, and while that's cool, I think BMW is still missing a competitor in this market segment for people actually looking for a car that can really perform.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching Previous: '14 550xi, '07 335i, '01 325i |
09-29-2014, 09:50 PM | #22 |
3161
Rep 9,134
You have not pushed your car to limits and yet you say it bests a E92 M3 w/ KW Clubsport coil overs. Very interesting. Care to elaborate or expand on those thoughts?
