Engine Problems, #5 mis Firing ?'s
09-19-2014, 03:17 PM | #1 |
Rep 80
Drives: 2007 335i
just went to the store, and punch it to get on freeway
attached is what my jb4 said was wrong , luckily i had my laptop in car and motor is clicking now any ideas on what it is, is it just a bad igination solenoid or spark plug or do you think its something worse? thanks
JB4, Cowl Filters, Oil Catch Can, Sport Oil Cooler Valve Modified bmw Clutch Valve, Short Shift Kit, Short Throw Clutch Stop, VSRF 7" IC, VSRF 3" Downpipes, HKS Bov SSq3, ER Charge Pipe, H&R Sport Coilovers, Spec Stage 2+ Clutch & Flywheel, Stoptech Brakes, BMW P Exhaust, Dual Cone K&N Filters |
09-19-2014, 03:21 PM | #2 |
3441
Rep 79,211
If your spark plugs have over 25,000 miles on them then it could be that.
Swap coil pack 5 to 1 and see if the misfire follows. If it follows your know it's the coilpack. |
09-19-2014, 03:22 PM | #3 |
Rep 80
Drives: 2007 335i
forgot to save pic
09-19-2014, 03:36 PM | #4 |
Rep 80
Drives: 2007 335i
thanks, i switched 2 and 5 and now 2 is misfiring
09-19-2014, 04:02 PM | #5 |
Rep 277
So then that would be a bad coil pack. Try change that pack with a new one and see if it continues to misfire. I would venture to say that the misfire will stop if you change that one. Then you will have solved your problem.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
09-22-2014, 01:00 AM | #6 |
Rep 80
Drives: 2007 335i
yep $33 on amazon for bosh , car fixed
