09-18-2014, 03:06 PM | #1 |
55
Rep 304
How Protect Underside of Front Spoiler?
Any thoughts on how to protect the underside of the front spoiler from being scraped besides not hitting anything? I already christened it coming out of a steep downward driveway onto a street. Nothing noticeable from the front, but scraped underneath. I'm certain to do this again somewhere, sometime. Especially of concern are parking lot stops/bumpers.
09-18-2014, 04:37 PM | #4 |
156
Rep 349
Luckily all the driveways I've gone over have been okay, although the front end barely clears it.
Besides approaching the driveway at an angle, there is not much you can do |
09-18-2014, 05:24 PM | #6 |
19
Rep 140
Surprised nobody has said this yet: Just be careful. If you scrape occasionally, that's okay. On cars with low(ish) right heights, the underside of the front splitter bumper might as well be categorized as a wear item. I rarely see 1-series (as an example) without at least a scratch or two down there.
09-19-2014, 12:05 PM | #7 |
24
Rep 123
My weekend car is a Porsche 997S with the factory aerokit. That car is REALLY susceptible to scraping. A trick that I've learned is to switch on the sport suspension, just before the obstacle, so that it not as compliant as it inches over the curb.
09-19-2014, 12:33 PM | #9 | |
95
Rep 809
Drives: 2014 228i Msport
A peasant and proud of it
Save The Manuals!!! |
09-20-2014, 09:11 PM | #10 |
1430
Rep 2,525
Drives: 2011 328i Wagon
Get a strip of the thick clear 3M film sold to protect headlights and stick it on under there. That stuff is TOUGH. No idea where you would get a piece that long, but where there is a will there is a way.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
10-01-2014, 07:57 PM | #11 |
55
Rep 304
I've been experimenting with the Park Distance Control as a means of protecting the front spoiler. If I turn it on just as I am entering a parking space with a curb/cement bumper ahead, the sensor will start beeping well in advance. If I turn on the Park Distance Control while I am very close to the curb/cement bumper, it will not start beeping. So if you turn it on well in advance, it helps by telling you the curb/cement bumper is ahead.
Try it and let me know what you think. |
10-01-2014, 08:17 PM | #12 | |
3074
Rep 5,577
10-01-2014, 09:53 PM | #13 | |
33
Rep 104
10-02-2014, 10:56 PM | #14 | |
127
Rep 765
Of course, when parking, could just get in the habit of backing into spots :P
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
10-03-2014, 08:49 AM | #15 |
1538
Rep 3,331
You think that's low? My Corvette had 1.5" of ground clearance between the air dam and the floor.
A lot of scraping can be avoided by driving habits. It will happen on occasion, not much you can do. Most of them won't be visible to anyone looking at the car unless they get underneath or it's extremely bad. -When you see a driveway that is steep, pull in at a very shallow angle and as slow as possible. This way the suspension doesn't load up and push the front end down further. Hard braking coming into a steep driveway will push the nose down and then with a sharp turn you aren't giving the suspension any angle to take the turn. Shallower the angle of entry, the less steep and less chances of scraping. -When pulling into spots you can use the PDC, but your better habit to form is remembering the front end of your car is fairly long in comparison to others. Don't feel like you need to pull up so far. The 2 series is a small car, chances are higher you'll hit the curb pulling way in than giving yourself an extra foot. Your car is still shorter than the lady next to you in the Expedition. Also just use other cars for reference. Remember FWD cars have shorter front ends so don't try pulling up to their mirrors, leave yourself a foot or so. -When exiting steep driveways same rules - pull out at a shallow angle. Sometimes this isn't possible (you'll block all the traffic) so in that case just go as slow as you can when pulling out. My 3 Msport bumper is fairly low and it's stayed in pretty good shape by following the above rules. Sometimes you can't get around it though and you'll scrape. I had a driveway in Miami that was so narrow you couldn't take it at an angle (otherwise you'd drop it off the curb) so the only option was to go super slow. It was so angled that even my exhaust would have hit if it weren't for the hitch installed.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
10-03-2014, 03:01 PM | #16 |
95
Rep 809
Darn, scraped again today. I never had this issue with my 128 sport. Maybe I should have gotten sportline instead of MSport. Guess I should just consider it a sacrificial part.
