Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > FlexFuel Wires question
      09-17-2014, 10:29 PM   #1
johnson47376
johnson47376's Avatar
33
Drives: 2011 335i e92 ///M
Recently moved to the Roanoke, VA area. No E85 for 50+ miles from where I live, so I probably won't be running E85 much. Simple question is should I remove the flex fuel wires I have installed for the JB4 since I won't be running it. Are there any effects of not running E85 now with the wires installed? Car seems to run fine, just wondering...
2011 E92 335i ///M Sport in SGM/ 19" Forgestar CF5V/
Pure Stg2 Turbo/ Pure inlet/ GFB DV /Fuel-it Stg2 LPFP/BMS intake/ JB4 ISO BMS BEF/AR Design DP/ ER CP/Wagner FMIC/ Wavetrac LSD/BMW PE/ KW Street Comfort / MusicarNW Level Two Audio Upgrade/CDV delete/3000K HID Fogs/ N20 plugs/ JB4 BT Rev3
      09-17-2014, 10:34 PM   #2
Jdub679
88
Drives: 2011 BMW 335i coupe M Sport
Not a single problem from running the wires without E85. If you're using Map 5, you might want to reset the map or select a lower map though.
