R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      09-17-2014, 04:12 PM   #1
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Placing M4 on jack stands?
Any tips on placing the F8x on jack stands? I see it has 4 really nice jack points, but if I'm lifting with the jack I can't put the stand there also? I lift the rear by the diff in my E36, but I really hate to do that on the M4 as those cooling fins look really long and delicate.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      09-17-2014, 04:42 PM   #2
FTS
Enjoying driving
FTS's Avatar
388
Drives: 645
There is a central possible welded jacking point apparently in the front, right in the middle of the metal cover (skid plate type thingy. Or, this may be a good solution: http://www.jackpointjackstands.com/
      09-17-2014, 08:25 PM   #3
M3 Esq
Automobilist
M3 Esq's Avatar
395
Drives: E70 X5, 911 GT3
I can only speak to my cars, but there may be a central lift point in the front as FTS said, plus you might be able to lift the rear at the diff. Not sure if the f8x is different, but that's how I lift my e92 and 335i. Once in the air, set the jack stands under the side jack points and lower. Good to go.
      09-17-2014, 09:55 PM   #4
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Thanks, might just (carefully) use the diff for the rears. I do remember something about a central jack point on my E60 M5. I think I'll need to tilt one side of the car up a bit to get my jack to it.
      09-18-2014, 07:20 AM   #5
jbraslins
Latvian Gangstah
jbraslins's Avatar
84
Drives: 2009 E92 M3 Melbourne Red 6MT
In the back, there are two black metal pieces (one on each side) that control arms connect to. I place jack stands under those.
Haven't figured out the front yet.
[SOLD] 2015 YMB BMW M3 M-DCT
[SOLD] 2010 Alpine White E90 M3 M-DCT
[SOLD] 2002 TiAg E46 M3 manual
      09-18-2014, 07:33 AM   #6
jbraslins
Latvian Gangstah
jbraslins's Avatar
84
That's pretty neat. They price is a tad steep tho.
      09-18-2014, 08:14 AM   #7
M3 Esq
Automobilist
M3 Esq's Avatar
395
Yes, you'll probably have to jack up one side to get a jack under the central front lift point. It's a PITA. Just get a lift and call it a day.
      09-18-2014, 10:35 AM   #8
Sir Loin
M3AT LOVER
Sir Loin's Avatar
322
Drives: Silverstone F80 M3
Please don't jack the car up using the diff. You will crush the cooling fins and possibly crack the diff housing as it is not designed to take weight.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
      09-18-2014, 01:02 PM   #9
M3 Esq
Automobilist
M3 Esq's Avatar
395
You can use a piece of wood to protect the fins. With the loads the diff sees on acceleration, especially in this car, I wouldn't worry about it not being able to support the weight. Plus there is no where else in the rear to jack from AFAIK
      09-18-2014, 03:00 PM   #10
jbraslins
Latvian Gangstah
jbraslins's Avatar
84
Not exactly correct. See below:
      09-18-2014, 03:05 PM   #11
jbraslins
Latvian Gangstah
jbraslins's Avatar
84
Appreciate 3
Sir Loin322.00
      09-18-2014, 03:38 PM   #12
M3 Esq
Automobilist
M3 Esq's Avatar
395
Yea I was referring to a rear central lift point.
      09-18-2014, 06:06 PM   #13
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Update: Using one side of the black "lower A arm" connection basically acts like a rear central jack point because this car is so stiff! Once the rear is up, just placed a jack stand at the far side rear jack point. The near side is only about an inch higher and place a jack stand there too. No need to mess with those delicate looking diff fins. Don't forget to put some good wheel chucks in front of the front tires!
Found the central front jack point (I think), but probably really need 2 floor jacks to safely utilize this to put the front two jack stands under.
Appreciate 3
      09-18-2014, 06:38 PM   #14
M3 Esq
Automobilist
M3 Esq's Avatar
395
Attachment 1092832
Attachment 1092833
Attachment 1092834
Nice work!
      09-19-2014, 04:55 PM   #15
Blue92
Drives: 2009 E92
Attachment 1092832
Attachment 1092833
Attachment 1092834
Roll her up onto a set of front ramps first, jack (with stands and/or block the rear) and the central point is all you need to get 2 more stands under the outboard points up front.
Delivered 02/20/09
LeMans Blue/6MT/EDC
      09-19-2014, 07:57 PM   #16
kitesurfer
kitesurfer's Avatar
No_Country
543
Drives: Round n' Round
Lots of bad advice going on in this thread
-NEVER lift from diff. You risk damage to cooling fins and/or diff
-lifting off center at red arrows has potential to be Very Unstable
Instead lift/jack at black Frame cross support pictured between the red arrows just behind the diff in the above pic..... you may need to cut a piece of 4"×4" lumber to fit between the exhaust pipes so the jack can support area. You may be able to use a piece of 2x4. On my e92 I need a 4x4
be safe
      09-20-2014, 08:29 AM   #17
M3 Esq
Automobilist
M3 Esq's Avatar
395
Instead lift/jack at black Frame cross support pictured between the red arrows just behind the diff in the above pic..... you may need to cut a piece of 4"4" lumber to fit between the exhaust pipes so the jack can support area. You may be able to use a piece of 2x4. On my e92 I need a 4x4
be safe
^ For shits and gigs I emailed the service manager at Turner Motorsport and asked if it was ok to jack from the diff. They said yes it's fine as the mounts are designed to withstand heavy loads. However, it was a general question and I didn't realize the F8x had cooling fins like that until I saw the pic, so not sure I would jack from there. FWIW I have always jacked my cars from the rear diff without a problem. I just put a piece of wood in between the jack and the diff to protect the surface of the diff. Just be careful when saying people are giving bad advice. It's very common to jack from the rear diff.
Appreciate 2
      09-20-2014, 09:21 AM   #18
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Yup, that could work. If I had ramps I think I know where I can "borrow" some.
be safe
I've always lifted from the diff on my E36, never had problems. The F82 diff fins are really long and thin so I avoided it. Guessing if you were careful and used a 2x4 you'd be fine though.
I lifted from the same black frame cross support you're talking about, just lifted about 10 inches off center where its actually bulkier and where it connects to the lower A arm. It wasn't unstable at all. Either way though, don't forget good front wheel chucks!
Agree with you. Thanks for giving him a call.
      10-15-2014, 11:47 PM   #19
kinimod
134
Drives: 911 GT3
I was researching this and found this thread... Aren't you guys overthinking it? There's a page in the manual that just says and shows to use the standard 4 jacking points next to each tire to lift the car for wheel changes.
      10-16-2014, 11:21 AM   #20
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Read the thread. We're talking about putting the entire car on jack stands using the stands at those 4 jackpoints you're pointing out. That way you can take all 4 wheels off at the same time.
Update: I had mine on 4 jacks stands. Had to use 2 floorjacks to access the front central jack point, but wasn't too hard. Ramps would also work.
Exclusivs540.50
      12-16-2014, 10:39 AM   #21
dmk08
Gone Fishin’
dmk08's Avatar
7315
Drives: Walks
So I was wanting to put my car up on all 4 stands today to remove the wheels before my trading partner gets here. Seems like that will be quite difficult if I don't have two jacks?
      12-16-2014, 01:21 PM   #22
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
Update: You CAN do it with just one good jack.
1) Raise rear up as described earlier (Place chucks in front of front tires).
2) Put 2 jack stands at the two rear jack points. Set the jack stands fairly high. Release jack from black suspension support near diff, now car sits on front tires and the two jack stands.
3) With the car now raised and tilted forward, there is enough clearance to slide a good low profile jack to the front central jack point. Run the jack in at an angle like from the driver side door. Be sure not to have the jack exactly where the front jack point is.
4)Now raise the vehicle from the central front jack point and place the remaining 2 jack stands at the front 2 jack points. Lower car. Done!
Hope this helps.
Appreciate 4
S65V8806.00
Suds1595.50
Search this Thread:
Advanced Search
f80post
