BMS DP, Cel fix and COBB tune question
09-16-2014, 11:17 AM | #1 |
45
Rep 531
About to pull the triggers on a BMS DP......I have COBB AP-v3, CP, K&N drop-in and BMW Perf exhaust. I know COBB corrects the light, but is there a real fix out there yet?
And, for those that have done dp w COBB, is it worth it? And what map can I run with above mods |
09-16-2014, 11:30 AM | #2 | |
314
Rep 929
Drives: 2011 BMW 335i xDrive manual
No dp fix for the n55 yet unfortunately. |
09-16-2014, 12:15 PM | #4 |
314
Rep 929
09-16-2014, 12:18 PM | #5 |
Is it the shoes!?
3884
Rep 5,112
The DP fix that they sell looks like nothing more than a simple resistor....but I could be wrong. If that's the case, man they're making bank off of each one of those.
09-16-2014, 12:24 PM | #6 |
314
Rep 929
I read somewhere that it's a lot more complicated to make one for the N55, which is why nobody has. I don't know details on why though.
09-16-2014, 01:46 PM | #7 |
324
Rep 2,014
I am Cobb pro tuned and I had the BMS dp installed last weekend. It's a night and day difference in performance and sound. The car turns heads now every time I drive it. You will love it!
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
09-16-2014, 01:57 PM | #9 | |
45
Rep 531
09-16-2014, 01:58 PM | #10 | |
45
Rep 531
09-16-2014, 03:14 PM | #11 | |
324
Rep 2,014
-50% 93/ 50% e85 pro tune done by PTF -VRSF charge pipe -BMS DP -BMS intake -Alpina b3 flash I did the e-tune with PTF and it is extremely easy. What they have you do is add the e85 then log with your current OTS map. You send them the logs and they use that to create a custom map based on your modifications, tire set-up, fuel, transmission, etc. When you receive the custom map, you install it, log and send the logs to PTF. They review the logs, make adjustments and send you a revision of the custom map. This process continues back and forth until your car is running perfectly. It could take 10-20 iterations. The thing I like is that the pro tuners at PTF are very knowledgeable. If your car is having issues that are related to the tune then they know what adjustments to make. If your car is having issues unrelated to the tune then they will help you trouble shoot and narrow things down. Also, they offer free lifetime re-tunes if you add mods to the car. For example, I had the pro tune for about a month and decided to add DP. They sent me a revised map to adjust to the DP within a day or so of me sending them logs. There are also shops that do dyno pro tunes but you would have to check Cobb's website to see their locations. I am under warranty until December and then my CPO kicks in. I found a cool adviser that understands these mods and wont void my warranty simply because my car is modded. In fact, he recommended that I get the DP. In the case that my mods do cause a problem, they will allow me to remove the mods and bring the car back in. I will be removing the tune and intake anyways for visits because it only takes 10 minutes max.
09-16-2014, 03:21 PM | #12 |
324
Rep 2,014
Catted may not throw a cel but I have heard that some do not pass emissions. And they perform slightly better than stock cats but nothing compared to catless. When you consider that they cost twice as much as catless, it doesn't seem worth it IMO.
09-16-2014, 03:49 PM | #13 |
38
Rep 463
The cobb tune can suppress the CEL that would be normally present with a catless dp, it doesn't just clear all codes like other tunes do. It basically ignores the specific code for catalyst efficiency.
I'm holding off on a DP until I can get a definitive answer, has anyone checked OBDII readiness with the Cobb "fix" in place? If it only leaves one monitor in the not ready state I'm fine. |
09-16-2014, 11:40 PM | #14 | ||
45
Rep 531
09-16-2014, 11:42 PM | #15 | |
45
Rep 531
09-17-2014, 08:51 AM | #16 |
38
Rep 463
09-17-2014, 09:45 AM | #17 | |
123
Rep 1,166
2008 e92 M3: Gintani Sport w/ Topspeed Catless X-Pipe, KW-V3
09-17-2014, 10:11 AM | #18 | |
324
Rep 2,014
Check out their website: http://www.protuningfreaks.com/tunin...otune-bmw.html
09-17-2014, 11:02 PM | #19 | ||
45
Rep 531
Pm me for the dealer and I'll give you the dirt. |
09-17-2014, 11:06 PM | #20 | ||
45
Rep 531
I'm worried about the BMS dp though, I want it but I'm concerned about removing it before service. What if my car dies or some shit and I can't get it to my Indy to remove dp? Unlikely but that's what concerns me. Also any diagnostic work at BMW won't be done until dp is removed just because of present CEL, how do you deal with that?? |
09-18-2014, 09:03 AM | #21 | |
324
Rep 2,014
