09-12-2014, 08:17 AM | #1 |
56
Rep 278
Car shut off (Drivetrain Malfunction)
EDIT: The LOW PRESSURE FUEL PUMP (IN THE FUEL TANK) was determined to be the failure and it was replaced under warranty.
Yesterday while making a left turn at an intersection, I received a "Drivetrain Malfunction" error as my car began to shake and hesitate. I managed to pull into a parking lot and the car shut off as soon as I stopped. I attempted to restart the car to no avail. The car was towed to my local dealership last night. From the mild research I've done I believe it's the high pressure fuel pump; however, I spoke with my SA earlier and he's going to take a fuel sample to make sure I don't have contaminated fuel. I'll keep this thread updated as I find out what's wrong. Hopefully this information becomes useful to someone in the future. Last edited by Hernandiaz11; 04-10-2015 at 04:09 PM.. |
09-12-2014, 08:25 AM | #2 |
Rep 205
Drives: 2014 335xi MSport
The smile-like design of the M Sport bumper should turn to a frown when being towed.
Good luck with the diagnosis, looking forward to what they find out.
2014 335i xdrive MSport AW/CR, SAT, Prem, Tech, HK, DHP, MPPK, MPE, NWA, KMFDM, etc... |
09-12-2014, 09:41 AM | #3 |
21
Rep 182
Bummer.
I've recently experienced a couple of instances of "Chasis malfunction - drive moderately" warnings --both from a starting/standstill in my driveway & while on the highway. However, after completing the drive, shutting off the engine and then restarting, it resets to show "No problem". The first time this happened, I contacted my service rep at BMW and his comment was that it sometimes is a computer glitch that resets. So far that is what has happened. Unfortunately in your case, much, much more was involved. Sorry you are experiencing this. Thanks for posting that you will keep an update running. |
09-12-2014, 09:54 AM | #4 |
Officer
Rep 95
I had the same issue happened to me two weeks ago and it was the High Pressure Fuel Pump. it seems that this a very common issue lately. Hope that you have better luck than me if that the issue on get the part replace as my car is still in the shop waiting on the part to arrive from Germany.
Good luck! |
09-12-2014, 12:13 PM | #5 | |
56
Rep 278
http://f30.bimmerpost.com/forums/sho...hlight=chassis http://f30.bimmerpost.com/forums/sho...hlight=chassis |
09-12-2014, 12:16 PM | #6 | |
56
Rep 278
The service adviser called me and told me that all of the symptoms lead them to believe it's the high pressure fuel pump (HPFP). They ordered it and it will arrive Monday. R&R takes 2 hours so hopefully the car will be ready Monday. I will let you guys know if this solved the issue. EDIT: The LOW PRESSURE FUEL PUMP (IN THE FUEL TANK) was replaced. Last edited by Hernandiaz11; 09-18-2014 at 07:54 AM.. |
09-16-2014, 08:48 AM | #7 |
56
Rep 278
The low pressure fuel pump was replaced (in-tank fuel pump) and I was able to pickup the car last night.
I hope my original fuel pump simply had a manufacturing defective (rather than a design flaw) which caused it to fail prematurely....I wouldn't want it to fail again in another few months. PS: My car currently has approximately 13k miles Last edited by Hernandiaz11; 09-18-2014 at 07:53 AM.. |
09-17-2014, 09:21 AM | #8 |
118
Rep 1,668
I think the HPFPs were redesigned from what i understand so the new version shouldnt have a flaw like the original ones.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
09-17-2014, 11:09 AM | #9 |
42
Rep 112
Similar issue happened to me two weeks ago. Dealer initially suspected HPFP but ultimately determined the HPFP was fine and the low pressure pump was defective.
09-18-2014, 07:52 AM | #10 | |
56
Rep 278
09-18-2014, 10:15 AM | #11 |
3262
Rep 6,299
06-06-2019, 07:30 PM | #12 |
Rep 2
hey hello i have a 328i f30 it happend the same car stop run after 100 the speed was goiing down and after i stop it start shaking like crazy we test everything cylinder 1 and 2 are no working went we unplug them we unplug the the 3r and car turn off we run the car again and unplug the 3r and car turn off
we check spark coil cable and injector. all good i was wondering if you had the same issue or you just send it to bmw? i only got error code p0300 powertrain multiple cylinder misfire detected p0301 cylinder 1 misfire p302 cylinder 2 help! |
06-07-2019, 07:57 AM | #13 | |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
