long crank before startup?
09-10-2014, 06:26 PM | #1 |
84
Rep 703
hello, i replaced my car battery and lpfp and still have a long startup from time to time. sometimes it seems to start right up, other times it takes about 6 seconds before actually starting up. what else could be the problem? thank you
09-10-2014, 09:26 PM | #4 |
421
Rep 1,643
I experienced this for over a year with no codes thrown. Finally threw a code that linked to hpfp, replaced it and starts right up, only 2-3 cranks now.
2007 E92 335i MT
09-11-2014, 08:20 AM | #6 |
84
Rep 703
Thank you everybody for the replies. I was under the impression that when the hpfp is dying upon startup the rpm needle moves erratically, I don't have that at all. Once the car starts up it is perfectly fine
09-11-2014, 08:41 AM | #7 |
Rep 17
Check your coils, have you thrown any codes? I have done more than one HPFP, and most recently ended up having one bad coil, and I checked codes right after start it had a "intermittent camshaft position sensor". Solved by replacing one coil. It would long start randomly, but always start.
09-11-2014, 11:13 AM | #9 |
3441
Rep 79,211
The rpm needles do not need to move erratically for the HPFP to be failing.
09-11-2014, 12:36 PM | #10 |
BimmerPost Supporting Vendor
24298
Rep 190,975
As mentioned above it is most probably the HPFP
If you are having the long crank only at cold start , it could be injector failing.
09-11-2014, 12:54 PM | #11 |
65
Rep 554
Drives: E92 335i 6MT
09-12-2014, 12:41 AM | #12 |
N54 to N55
66
Rep 308
09-12-2014, 08:12 AM | #13 |
65
Rep 554
No, the car ran relatively strong too, much stronger with new plugs and injectors though. First dealership gave me the no codes = no problem diagnosis, had to go to another dealership and they replaced both banks (1 leaky injector in each bank) under warranty.
