Slight Drop in Gas Mileage with Dinan Flash
12-23-2007, 11:28 AM | #1 |
2753
Rep 4,445
From my rough experiment it appears I lost about 1-2 mpg. I was averaging almost 30 mpg on the highway at cruising speeds now I'm around 28-29 mpg. Just thought you fellas may want to know.
12-23-2007, 11:45 AM | #2 |
111
Rep 1,764
Dam, I wish i was getting your numbers.
The stock car was getting 11 to 12.5 MPG on average. I just hit 13+ mpg for the frist time ever with the Dinan flash but will see if that changes as it should. I should say do mostly city driving. I mentioned that my not so good gas milage to dealer but they said it is about normal Orb Last edited by Orb; 12-23-2007 at 02:54 PM.. |
12-23-2007, 11:58 AM | #3 | |
2753
Rep 4,445
Well Orb is sounds like your lead foot needs to go on a diet
12-23-2007, 11:59 AM | #4 |
327
Rep 4,484
Yes, with ANY of the tunes you will get less gas mileage than stock.
Two reasons: 1. More boost = more gas 2. You drive the car harder now with the added power we all love. On a side note, I'm not sure about the others, but with the PROcede, under normal driving you actually get a bit better gas mileage. But who with a PROcede (or any other tune) drives the car lightly?? |
12-23-2007, 12:10 PM | #5 |
812
Rep 3,974
I was getting 13mpg when the car was fairly new. However, after a couple 800 mile road trips, my average is all the way up to 17mpg now in 9800 miles of driving. If you are on the HWY, on cruise control at 70mph, you should be getting 28-30mpg on your instantaneous. Any slight up hill grade, or headwind, and it will go down significantly. A slight down hill, and the MPG will sky rocket into the 40's etc. So a slight up hill run may be 1/2 the fuel economy as going the other way downhill on that same road. This is why I think 1/4 mile strips that go uphill take a measurable toll on your performance. An extreme example would be the 6% grade on the 101 fwy down here, 16mpg up hill, and 99mpg down. You can easily achieve 100mph in neutral going down the grade. Another perfect example: did you ever try and push a broken down car up a hill you normally don't even feel when you a driving? Compare that to pushing it in the down hill direction. I'm sure you get my point. Also, our cars probably get the best fuel economy in hot weather. More efficient, less drag. But of course, less power also.
12-23-2007, 12:15 PM | #6 | |
111
Rep 1,764
Good point as I only have 2500 miles on my car. I'm lucky to do 5000 miles a year |
12-23-2007, 12:21 PM | #7 |
2753
Rep 4,445
Well, there are no hills here and I am near 10k now, so maybe the mileage improves a bit.
Driver72 I agree about driving the car harder with a tune, but I tested under cruise control with a constant speed. So I agree the boost increase does cause the mpg to decrease.
12-23-2007, 01:27 PM | #8 | |
148
Rep 5,389
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
