V2.02 Limp-less map: Thoughts & Questions
12-23-2007, 05:46 AM | #1 |
Rep 18
Drives: 335i + Procede V2
The latest V2.02 map is the perfect combination of power and smoothness.
The car accelarates smooth but powerfull at the same time. I cant think a better way for these two values to be combined. Congrats to Vishnu guys ...amazing job BUT...I'd like to share with all of you some conserns that came up after two days driving and datalogging of this new map and I would really appreciate your help. Dataloging: i) Despite the satisfaction while driving (using default 90%) , my latest datalogs had really caused me some conserns. The turbos appears to spike randomly while driving. I'm reaching the levels of 15,0 to 15,4 psi. This is mainly happens when i release the gas pedal (its odvious that the spikes happens when the rpms are decreasing). Could this be happening due to the fact I'm comming from a V2.02 map that was set to 97% ?? ii) While the car is idling the Pde reader reads -0,4/-0,3 psi and when i swich the engine of , is set to 0,4 psi. Is that right?? Driving/Cruisin iii) After the V2 installation my cruise control doesnt work properly. Do the delimiter connections mess up with cruise control? iv) Whenever I release the gas pedal (even while driving gently on the streets), the car makes two slight kicks to the front. I never felt that with 1,47. Is that has to do with boost spikes as well?? I noticed from the datalogs that the spike occurs some m-secs after the rpms starts dropping (not immediately). I wish that Shiv could enlighten me on this. Thanks |
12-23-2007, 05:54 AM | #2 |
788
Rep 7,246
Amen brotha.....im about to install this soon
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
12-23-2007, 05:55 AM | #3 |
788
Rep 7,246
Or is this really just Shiv pulling a classic "terry" move by making a fake account just to boost his own product haha? jk jk
12-23-2007, 07:00 AM | #4 |
Rep 116
Well, for what its worth...
When I had my chipped Audi S4, at idle the car would normally show less that 0 PSI boost on my boost gauge, and slightly over when turned off. Its normal, and I used to remember the reason why, but getting old sucks, and I had to dump those memories in lieu of kids birthdays. also, there's almost always a slight spike as you get off the gas, as the engine adjusts for the new load, and releases any extra boost that you may have built up (at least in the Audi anyway).
07 BMW 335i Sedan, JB2, Jet Black, Premium, Sport, Heated Seats, Hardwired V1
01 Audi S4 Stage I (APR) (sold) ??-01 Nothing worth mentioning |
12-23-2007, 07:03 AM | #5 |
Moderator
270
Rep 4,481
I do not see something being not normal on the datalog. When you close the throttle ( as it happens during shifting ) a little boost spike is built up in the boost system. This is completely normal, thus the boost is measured before the throttle valve.
I had the same cruise control issue when I changed from v1.47 to v2.0.0. After removing the thick black battery wire for 1 hour, which forces the ECU to learn from scratch, cruise control has been perfect again. It seems you have an auto, as I have, and run the latest 2.0.2 12-19 map. The second little boost spike during shifting will disappear once Shiv will release dedicated maps for 6AT's and 6MT's again, as it has been before the current map. My 2 cents and V2 experience so far. - Eugen |
12-23-2007, 08:53 AM | #6 | |
Rep 18
Eugen-I'm driving a 6MT and I have not reseted the ECU when jumping from the previous version of V2 to the new one. I'm also VERY conserned about the "slight kick" when releasing the gas pedal. Does anyone feel that as well? I was out driving right before and the feeling of this "kick" just getting on my nerves. IT SPOILS THE BMW DRIVING FEELING |
12-23-2007, 10:21 AM | #7 | |
ocasionally in crisis
52
Rep 2,358
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
12-23-2007, 10:47 AM | #8 |
Rep 57
From my experience I think I can answer some of your questions:
i) There are two spikes in your datalog. The largest one occurs on sudden throttle closure and is not seen at the intake manifold and thus is harmless and normal. The other slight spike is occuring on sudden throttle opening. It appears at though the system is overshooting the desired boost level under certain conditions in 1st/2nd gear. This happens to me -- it was much worse in with the 2.0.1 map but is now very minor in the 2.0.2 map (since I understand shiv reduced the ramp rate). In any case it looks fine. ii) The idle PSI reading is dependent on altitude. At sea level mine reads 0.4psi. Nothing to worry about. iii) Can't help here, I didn't install this. iv) I don't think this is related to the throttle closure spike (not seen by engine). In which gears are you feeling this? |
12-23-2007, 11:05 AM | #9 |
24
Rep 1,310
Checkman - when you installed the new map, did you disconnect the negative battery terminal for an hour before or after the upload? I know there's no scientific proof that this makes a difference, but I do it every time I upload a new map and I haven't had a single issue with V2 thus far (knock on wood...)
My boost curve looks like yours and except for the close-throttle peaks of 15psi, I am now boosting around 12-13psi. The thing that's different between V2.0.1 and 2.0.2 12/19 map, are the boost curve lines were smoother from data point to data point. I've only driven the car about 30 miles since installing it yesterday, so perhaps they'll smooth out. Here's what I mean: One of my most recent 1/4mi runs: Here is 2nd-4th gear pull from yesterday: The first boost graph (from a dragstrip pass a couple weeks ago) has a line which is pretty smooth. The second (from inital v2.0.2 map testing yesterday) is somewhat sharp and jagged. It looks more like the OP's line. Drivability is awesome. I know the boost is down but it just pulls hard and smooth all the way to redline. Nothing unusual at all about the way the engine feels or sounds. Anyone know why the jagged boost line now? I'll do some more driving today and log the curve to see if it smooths out... |
12-23-2007, 11:15 AM | #10 | ||
Rep 18
?? Sorry English is not my mother-language ?? What do you mean?
I was trying to "play" with the pedal , releasing it even softer ,but it looks like its doesnt help much. I also use the clutch to help it but this is not the right way to do it. Dont think thats something TOO intense but its definately annoying when you're stuck on trafic and drive rather slow. Any input would be much appreciated. Anyone else noticed this? Quote:
It looks like we cant avoid spikes..can we? |
12-23-2007, 11:28 AM | #11 |
Rep 62
maybe shiv can post a stock map so that we can see if boost spikes are present in "stock" mode. Maybe if there are, we can put an end to all the needless concern
12-23-2007, 02:23 PM | #12 |
Rep 18
No..there are no spikes on stock one. We have already made tests using boost gauge on stock car. Its just refuses to go above 0,4 bar (6psi i think).
We ve seen no spikes so far on stock car. |
12-23-2007, 02:27 PM | #13 | ||
24
Rep 1,310
Boost spikes occurring at a gear change are caused by the throttle closure and are not seen by the engine. This has been gone over several times in the last few weeks. |
12-23-2007, 02:27 PM | #14 | |
175
Rep 1,517
Drives: E92 335i coupe Black AUTO
12-23-2007, 02:29 PM | #15 |
24
Rep 1,310
There was a thread proving that the stock motor spikes (albeit at a much lower psi) several days ago. Just do a
12-23-2007, 02:32 PM | #16 | ||||
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
1) You didn't have a logging software to see it. 2) Stock boost was much lower. Quote:
-shiv |
12-23-2007, 02:35 PM | #17 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
12-23-2007, 02:35 PM | #18 | |
24
Rep 1,310
Disconnecting the battery just allows it to learn from scratch with the new changes you've made. The 50 mile recommendation is for safety, but I belive someone at Vishnu said that several pulls to redline to log boost levels would be enough to determine if you can (or would want to) change the user map settings from default. Disconnecting the battery cable is so simple and resolves so many strange errors and problems, It's become a standard procedure for me. The only time I ever had an anomaly was when I forgot to disconnect the battery cable. Your mileage may vary, of course! |
12-23-2007, 02:48 PM | #19 | |
Rep 18
Thanks for your replies. I appreciate that. So the only issue to be resolved is the kickback of the car, when throttle is releasing. I will revert to stock map and see if the same issue occurs while on stock map. I dont remember the car behaving like this before. I will also try another car to cross-check. Thanks again...if I have any news about this i will let you know. |
12-23-2007, 07:13 PM | #20 | |
441
Rep 18,331
12-23-2007, 08:41 PM | #22 | |
Dancing Machine
47
Rep 1,419
2007 e90 & 1981 Corvette Predecessors: 2007 BMW 335i E92, 2006 M5, 2008 Viper SRT10 Coupe, 2005 Viper Yellow, 2006 Corvette Z51, 2009 Challenger SRT8, 2006 S4, 2001.5 Nogaro Blue S4, 2006 GTI w/ DSG, 06 Evo IX, 04 S4, 04 911x51, 03 Evo VIII, 98 Eclipse GSX, 96 GST, 92 Galant Vr-4, '70 Grand Prix Model J, '70 Nova, '68 Firebird
