Backpressure Exhaust Q
12-22-2007, 06:22 PM | #1 |
Rep 248
I recently got the Reiger rear diffuser and as a result had to cut off the back pieces of my exhaust and had some custom work done to put in new tips and (with some 90 degree bends and what looks like a slightly thinner pipe) to make it fit the diffuser. Now ALL MY POWER IS GONE!!! I feel like a jackass driving around a sick looking car with less power than stock considering the upgrades I have on the thing.
A mechanic told me that by going to some bigger tips, there isn't enough back pressure in the exhaust to spool up the turbos, and that might be what is going on. Personally I think the opposite. It seems like the custom bends and smaller piping at the end of the exhaust (it was a rush and honestly poorly done job...) is restricting airflow. When I drive above 4k rpms it sounds almost like a hose is loose in the front engine, or that the blow of valve is just constantly venting air. Additionally, there is almost no blow off when I do shift up. Wouldn't these be the symptoms of too much back pressure? I have considered just lopping off the shitty custom work and driving around in a weird looking and obnoxiously loud car, but at least I'd be able to drive away fast from all the haters... Any suggestions? Someone PLZ !!!
Modded. |
12-22-2007, 06:27 PM | #2 |
104
Rep 315
Turbo cars dont need backpressure and you screwed yourself by adding another bend. When it comes to turbos you want the exhaust to get out as quick as possible, thats why you get a bigger exhaust wit as few bends as possible. that will solve your power issue
12-22-2007, 06:46 PM | #5 |
Rep 248
No can do, no camera... Looks real good but I'm not sure what exhausts are supposed to fit it... it's really wide and there are parts of the car that get in the way.
Modded. |
12-22-2007, 08:03 PM | #8 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
also with exhaust modifications usually you hear the turbo spool a lot more, this could be the "constant venting" sound you hear
2007 335i Coupe Mods: Check the Garage |
