V2 new map check engine?
12-22-2007, 03:27 PM | #1 |
27
Rep 298
any of you guys with new 2.2beta map and new firmware have problem when starting car cold, RPMS jumping up and down? I do have that problem until i turn my car off and on and then it works fine, please respond i would like to know if im the only one
thank you |
12-22-2007, 04:24 PM | #3 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
12-22-2007, 05:02 PM | #4 |
109
Rep 1,948
No issues here and i've left my car in hot and cold temps outside. Never affected startup and or idle. It's possible that the connections to the procede wiring may not be connecting?
12-23-2007, 12:17 PM | #5 |
99
Rep 1,712
No you are not the only one. Mine has been doing this recently on cold startup. To the point where it goes in limp mode. Restart and it's gone. IF this keeps up I may revert back to the 2.02 MT map where I had no trouble (assuming the map is the cause). Shiv: could it be a loose wire connection??
12-23-2007, 02:21 PM | #6 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
12-23-2007, 09:42 PM | #7 |
Rep 153
Mine loaded with 2.0.2 19-12 does the same thing when starting from cold.. I reflashed back to the older firmware and v2.0.1 map and didn't get the problem anymore.
Thing is, the problem is repeatable! All I have to do is flash the new firmware and upload v2.0.2. Rpm will gallop continuously then go into limp. Power cycling the engine usually fixes the problem though. Nothing has changed with my hardware(ecu/procede) during this time. |
12-23-2007, 10:25 PM | #8 |
tizzlebag
50
Rep 325
I get the same problem too...never had the problem with the V1.47. I dont think its because of loose wires because a few other people have this problem. I live in Southern Cali so its definitely not because of a cold start.
Any suggestions?
2017 AW M2
2016 X5 2011 528i |
12-23-2007, 10:40 PM | #9 |
441
Rep 18,331
oh no V2.02 12-19....I hope thats not the issue...because i like this map and i don't want too many changes again if there is problems...But i did feel a jerk or hestitation from light throttle from a stop..happened twice from initial upload of firm and map....Since 80 miles or so no problem, smooth idle and not jerk feeling felt again from a stop
12-23-2007, 10:56 PM | #10 |
219
Rep 8,375
Drives: Just a car
I had the same problem once few weeks ago with V1.47, rough on cold start then turn off and on again, it was fine afterward....Shiv told me it may be my fuel pump issue....but since then...never happen again.
12-23-2007, 11:15 PM | #11 | |
178
Rep 1,432
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| |
12-24-2007, 08:56 AM | #12 | |
441
Rep 18,331
12-24-2007, 09:25 AM | #14 |
Rep 15
I installed the latest V2 map and keep getting the Service Engine Soon (SES) with a code of 0503. I also did the speed delimit mod. I hope I did everything correctly.
I loaded the delimit V2 map and did the following mod with my old Green loom: - I extracted the white/green wire of pin #17 of the grey subconnector of the smaller ECU connector and connected it to pin #4 ( digital input #4 ) of the black PROcede connector. - I connected pin #9 ( digital output #4 ) of the black PROcede connector to pin #17 of the grey subconnector of the smaller ECU connector. The SES light only comes on after driving for a few miles while in 4th at low RPMs. I have put 100 miles on the car so far and it has throne the code both times after I have cleared it. Any ideas?
Bill(Boweryboy)
09 Cadillac CTS-V 6MT 06 Corvette Z06 Vette Doctors Rx650HP / 97 C5 LS2 IRS TH400 Rear Turbo 1500HP 8.50@178mph / 90 ZR1 #2547 Turquoise 07 BMW 335i Coupe-Vishnu V2.02(RiP) Last edited by Boweryboy; 12-24-2007 at 10:34 AM.. |
12-24-2007, 02:18 PM | #17 |
27
Rep 298
no loose wires here 100%! so it has to be the MAP,becouse it never had happened before on any other map v1 or v2, also new map at 96% TQ will give you check engine light at high RPMS, but there is way out, just set 6000 rpms at 96% TQ 6500rpms at 94% TQ and 7000rpms at 92% TQ 7500 rpms and up at 90% TQ and it will be fine, i had burned 3/4 of tank to day to test it and it works fine with those setings
12-24-2007, 03:07 PM | #18 |
tizzlebag
50
Rep 325
Just started my car today with no problems. It's only the third day with the new map so if I ever get the cold start problem again, I will update you guys.
2017 AW M2
2016 X5 2011 528i |
12-24-2007, 04:18 PM | #19 |
Rep 301
freaking crazy.. Whats up with testing these days?
535i -
Black Sapphire/Black Dakota/Bamboo/AnthraciteHeadliner/M-Tech Kit/Spoiler/Sports/Premium/Navi/HUD/Comfort/Rear Shades/ParkDistance/Ipod/Sports Auto w/Paddle/Logik7/30% Tint/Clear Bra/KW3/ Radenergie rs10 20"/Defi RedRacer Psi/Smoked front reflectors/ LED interior lights Soon: Rpi Catback, GIAC or EVOtech flash, Dinan Rear Strut, OEM M5 Mirrors |
12-24-2007, 04:21 PM | #20 | |
274
Rep 6,510
So should 2.0.2 users downgrade to 2.0.2 ? or maybe stick with 2.0.2, or even go to the original 2.0.2 ? LOL good thing there is LITERALLY 5 versions of 2.0.2 ... all with problems... makes it easy I think someone else might be the one with a wire loose this time... no offense of course |
12-24-2007, 04:26 PM | #21 |
1737
Rep 17,960
Drives: A Lot
FWIW, I emailed LuckyD a map that extends the time that the PROcede is bypassed during start-up. We'll see if that makes a difference to his start-up condition. I'm not posting it here because I can't see how the new changes can possibly make any difference with respect to start-up. And I don't want to flood the forum with new maps. When dealing with 0s and 1s, anything is possible, of course. So we are looking into it the best we can without ever having seen this condition ourself.
Shiv |
12-24-2007, 04:28 PM | #22 | |
274
Rep 6,510
Merry Christmas |
