Coolant High Temp help
09-05-2014, 12:52 PM | #1 |
Rep 61
Hey everyone, I've been having some intermittent coolant high temp alarms. After roughly 35-45 minutes of driving, the yellow alarm will appear, and the red alarm about 10 seconds later. It will go into turtle mode. I can pull over, and turn off my engine and restart, and the alarm will clear for another 30 minutes. The first time it happened, there was a small amount of coolant that leaked by the reservoir cap.
If anyone has any input, it would be greatly appreciated. Thanks!
2011 E90 335i
JB4-Flex Fuel wires-BMS Intake-Vishnu catless DP-Vishnu CP- M3 Front bumper |
09-05-2014, 02:49 PM | #2 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Water pump is shot. Happened to me 4k miles ago, exactly the same.
09-05-2014, 05:01 PM | #3 |
enthusiast
117
Rep 997
Drives: 2011 e92 lci 335xi
it's almost common knowledge around here n55/n54 that when you get yellow warning than the red over heating warning.. it comes down to the water pump/ thermostat ... I'm at 33k miles and on the highway going 70 cruise control with air condition on I got the yellow than red warning light.. when it happened I knew instantly it was the water pump, thankfully my warranty only went up few months ago so bmw helped out with the cost.. only paid 250 for new water pump and thermostat including labor.. at any rate, do yourself a favor and get it taken care of asap because the coolant is meant to keep some very important engine components cooler.. so when you are driving around with a bad water pump you are really taking a risk of causing major damage, also note when your rad fan kicks up it is trying to make up for the high coolant temp by increasing air flow through the radiator. update us when you replace the water pump which im positive is the issue in your case
09-06-2014, 04:41 PM | #5 |
Foodie and Gearhead
102
Rep 733
Drives: 2011 335i xDrive Sedan
It's upsetting that even later model year E9x 335s need to worry about this. You'd think BMW would have gotten their crap together. I'm really curious what's causing all these failures.
2011 335i xDrive Sedan, Deep Sea Blue w/Oyster Interior
09-09-2014, 06:42 PM | #7 |
Rep 61
So... I brought it to the dealership today, and they cannot positively identify it as the water pump or thermostat. Apparently, they were not getting the code for the motor failure, as they should. They said it could be a fault in the wiring, or something similar. I was in a recent collision, and the advisor said it could also be from that.
Any thoughts?
2011 E90 335i
09-09-2014, 09:22 PM | #8 | |
enthusiast
117
Rep 997
09-09-2014, 09:25 PM | #9 | |
enthusiast
117
Rep 997
09-18-2014, 10:41 AM | #10 |
Rep 61
Great news... I took my car back to the dealer, after the problem became more frequent, and they did determine it was the water pump and thermo. Since I am only at 53k miles, they are replacing everything 100% free of charge. Also, since the Vanos bolt recall is officially out, and no longer pending, they are replacing the bolts as well
2011 E90 335i
