Can someone with a stock airbox post their IATs?
09-03-2014, 06:32 PM | #1 |
Came to the N55 Darkside
1112
Rep 12,740
Here is mine all warmed up with a BMS intake:
09-03-2014, 07:52 PM | #5 |
1112
Rep 12,740
Yes sir- for the N55 of course. For N54 you gotta tap into the vacuum line. I've gone back-and-forth with debating selling the gauge... Still on the fence
09-03-2014, 07:55 PM | #6 |
44
Rep 394
09-07-2014, 01:48 PM | #9 |
28
Rep 300
Drives: '11 335i
Not to many people with a p3 still have stock intake...
09-07-2014, 01:59 PM | #10 |
enthusiast
117
Rep 997
Drives: 2011 e92 lci 335xi
worst case .. if you currently have the bms n55 intake .. it's extremely easy to take off and throw the stock air box back on.. and plus your numbers might be slightly different than someone else.. I say go for it yourself!! I could do it for you but too lazy lol.. btw awesome p3 gauge did you install it yourself?
09-07-2014, 02:06 PM | #11 | |
1112
Rep 12,740
Actually no I didn't- Prestige BMW in Ramsey did it believe it or not- they're my "go to" guys for any engine related stuff since I did all my Dinan with them. |
09-07-2014, 02:08 PM | #12 | |
1112
Rep 12,740
Well, the thing is, it doesn't even have to be a P3 gauge- maybe my title is misleading to people. I just want to know what the IAT temperature is for a stock airbox as a baseline I suppose. |
09-07-2014, 02:29 PM | #13 |
1161
Rep 3,189
You would have to find someone in the exact same climate, same mods and same exact fuel to be able to compare. People can tell you their IAT, but it will be useless.
09-07-2014, 02:42 PM | #14 |
1112
Rep 12,740
You know what I never thought about that- you have a point sir!
Well here's a question for everyone then: Hypothetically, given the exact same environment and climate, would the temperature be lower for a stock airbox or a "cold air intake" like the BMS intake? |
09-07-2014, 04:55 PM | #15 |
28
Rep 300
Drives: '11 335i
Higher temps with the bms since it pulls air from the engine bay and not the grill. Bms will suck more air but it's warmer
And to be considered a "cold air Intake" it would need to pull air from outside of the engine bay. Stock is technically more if a cold air intake than the bms |
09-07-2014, 05:11 PM | #17 | |
28
Rep 300
Drives: '11 335i
09-07-2014, 09:15 PM | #18 |
1112
Rep 12,740
Well I have the upgraded FMIC covered, but I refuse to get downpipes so I guess I'm in the best spot I could possibly be. Thank you all!
09-07-2014, 09:46 PM | #19 |
143
Rep 567
If you let it sit and idle the IATS will climb. My car is a n54 but with the stock box and a mr5 style box I see 10-15 degrees about outside temp. When it idles it rises but I don't recall it ever being about 115ish
07 335 6MT
09-07-2014, 10:32 PM | #21 |
Rep 194
Sitting in traffic, or idling with the BMS intake on a hot day results in 135+ degrees in a short amount of time!
And that's with an upgraded intercooler and DP.... However, running down the highway or under full throttle, I'm only seeing a +15 degree temp difference that's pretty slow to climb. |
