COBB N55 Charge Pipe
09-01-2014, 08:24 PM | #1 |
17
Rep 187
Drives: SGM e92 335i M-sport
Looks like COBB now has a charge pipe for the N55 (and N54 as well). Linky. Not a bad price either. Definitely considering it since I'm still running an OEM CP.
09-02-2014, 08:10 AM | #3 |
123
Rep 1,166
Finally someone is starting to compete with VRSF for affordability. Cobb's DP cost is still a little ridiculous though.
2008 e92 M3: Gintani Sport w/ Topspeed Catless X-Pipe, KW-V3
09-02-2014, 08:36 AM | #5 |
324
Rep 2,014
Anything will be better than stock.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
09-04-2014, 01:36 PM | #6 |
BimmerPost Supporting Vendor
24198
Rep 190,805
09-04-2014, 11:37 PM | #7 |
2095
Rep 43,350
I'm surprised they're in line with our pricing, this is probably the most affordable Cobb product yet
Too bad they're using worm gear clamps though, definitely a down grade over the t-bolts most of us offer. |
09-05-2014, 02:06 AM | #8 | |
72
Rep 436
09-05-2014, 03:13 PM | #9 |
Rep 100
We stopped using regular t bolt clamps on the 60+psi diesel stuff many years ago due to inconsistent clamp force and localized distortion around the circumference of the hose.
A constant torque worm drive with safety wire on a properly bead rolled pipe is more reliable, at the level where clamps start having issues you also need to attach your pipes to each other or make sure each is rigidly mounted. |
09-05-2014, 03:33 PM | #10 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Yes, worm drives are more even, but you have the issue of the silicone being destroyed from being pressed in the slots. Wiggins clamps are the way to go if you are going big.
09-05-2014, 03:39 PM | #11 | |
Rep 100
09-05-2014, 04:54 PM | #12 |
enthusiast
117
Rep 997
Drives: 2011 e92 lci 335xi
wow amazing price for a cobb product
09-08-2014, 10:45 AM | #13 |
.some.assembly.required.
13
Rep 47
Drives: 2011 335i Saloon (e90)
Hey all...long time lurker and finally 2011 e90 owner!
Thought I'd share my first (supporting) mod, as it's related to this post. The Cobb Charge pipe seems to be of a nice quality...but what a PITA to install to the TB portion!!! Last edited by LiquidxStorm; 09-09-2014 at 10:19 AM.. |
06-29-2015, 01:54 PM | #14 |
Rep 1
LiquidxStorm For the life of me I can't get the Cobb charge pipe to fit onto the throttle body, do you have any tips? I've used silicon lube and I'm forcing it so much on and I'm conscious about how much pressure I'm applying... PLEASE HELP!
06-29-2015, 01:59 PM | #15 |
3441
Rep 79,211
Contact Cobb direct before you break something. There have been a lot of issues with the Cobb CP's. You may end up wanting to return it and look into something like the ER Charge Pipe. It's a little more expensive but at least it fits!
06-29-2015, 09:56 PM | #17 | |
118
Rep 558
Can you please specify what is the problem with flanges? Do you have pictures of defective units? Thanks |
06-30-2015, 09:58 AM | #18 |
Joint Chiefs of Staff
4918
Rep 115,980
06-30-2015, 05:39 PM | #19 |
118
Rep 558
06-30-2015, 08:57 PM | #20 | |
13
Rep 47
