08-31-2014, 10:05 AM | #1 |
2712
Rep 2,371
Spacers and Handling
I like how the M4 looks with some spacers, but have always been told (from previous track experience and from listening to others) that spacers will probably have a negative effect on handling, plus they add in another point on the wheel and hub (even with hub centric spacers) that is a weak point, susceptible to failure.
What's the general consensus on spacers (if there even is one)? |
08-31-2014, 10:19 AM | #2 |
1030
Rep 1,190
Spacers affect handling a few different ways.
They increase the track width, which generally helps overall grip. They increase the scrub radius, which increases tire wear and reduces steering feel. They reduce the effective spring and damper rates because they now have to react against a longer lever arm. They add another possible point of failure and can increase load on the lug bolts. These effects will vary in size depending on now big of a spacer you use. The consensus is probably that none of this stuff really matters and that you should do it because HELLAFLUSH YO! This is probably true on the street. For the track, the biggest concerns would be the loss of spring/damping rate and the extra load on the lugs, which can both be mitigated with other modifications.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
fiveninerzero18.50 |
08-31-2014, 11:36 AM | #4 | |
Ring Leader of G8X Trolls
802
Rep 1,762
08-31-2014, 03:24 PM | #5 |
Straight outta Loca$h
39
Rep 359
Appreciate the thread OP and always appreciate Racer20's thoughts. I did a search on this last week and didn't have enough time to find this exact answer. Figured it would alter OEM setup but this gives good info as to why. Thanks again.
2015 F80 ///M3 (AW/SO|6MT|Exec|LED|HK|M Susp|Black 19s|Cameras)
ED Date: October 13, 2014 PCD Date: December 5, 2014 |
08-31-2014, 10:13 PM | #9 | |
2712
Rep 2,371
Easy peasy. |
09-01-2014, 12:34 AM | #10 |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
Some dealers won't touch a car with spacers. Any track car shop has no problem with them though. There's probably as many guys running spacers as not in my track club. Never seen a catastrophic fail because of them. I tracked my M4 today with 12 and 15mm spacers, never worried a bit. I would torque your lug bolts carefully which you should be doing anyway.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
09-18-2014, 10:25 PM | #11 |
Rep 95
Hellacious hoy
I have been researching and wandering what spacer width (front and rear) that will give that HELLAFLUSHYO look?
TXgrown
2018 x5 50i |
09-19-2014, 11:55 AM | #12 |
28
Rep 118
09-19-2014, 12:01 PM | #13 |
3446
Rep 4,186
i'm running 20mm/18mm and lowered on 435 H&R Sport Springs with no rubbing on my M3
-JLT- |
09-19-2014, 12:09 PM | #14 |
Gone Fishin’
7318
Rep 12,125
09-19-2014, 01:58 PM | #15 |
3446
Rep 4,186
not a big difference to tell u the truth. HELLAFLUSH YO!!!! haha
-JLT- |
09-23-2014, 11:46 PM | #16 |
2337
Rep 2,028
Drives: INDIVIDUAL F90 M5C LCI
As far as day to day driving (no tracking) have you noticed any rubbing/negative affect at all?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
09-24-2014, 01:34 PM | #17 |
3446
Rep 4,186
none whatsoever
-JLT- |
01-08-2015, 05:30 PM | #20 |
23
Rep 93
Also have 15mm front, 12 mm rear Macht Schnell spacers from EAS. I've heard good things about Turner Motorsports spacers.
I personally don't feel a difference in the steering feel of the car, but I'm a street only driver. As far as dampening, I've lowered the car with KW HAS so I can't comment on spacer effect on stock dampening. If you head over to EAS's (European Auto Source) thread, http://f80.bimmerpost.com/forums/sho....php?t=1017256, there are many of us with spacers, lowered and unlowered. I'm sure any of these guys will share their experiences with spacers. |
01-09-2015, 05:52 PM | #21 |
154
Rep 438
I have 18mm front and 15mm rear Macht Schnell spacers on my F80. I've had spacers on several of my cars and have tracked all of them with no issues whatsoever. For those of you that are concerned with the potential negative effects that spacers will have on handling, consider this... Porsche offers spacers as a factory installed option on many of their models, including the 911. I'm confident that Porsche engineers know what they're doing, and they wouldn't offer spacers if they had any cause for concern.
