08-28-2014, 05:37 PM | #1 |
103
Rep 335
F10 wheels and tires
From what I've read here, it seems this will work, but a reality check would be really helpful. I have a chance to pick up a set of wheels and tires and want to be sure that there won't be any issues with them on my F30 xdrive. It appears that these are about 2% taller than OEM and there is a difference in the F and R diameters of 0.6%...I've never seen an exact spec for how close this has to be for xdrive.
F: 19x8.5 ET 33 - 245/40 R: 19x9 ET 44 - 275/35 If anyone could point me to a picture with similar wheel/tire size on an F30 AWD or RWD, I'd appreciate it. |
08-29-2014, 08:44 AM | #2 |
1863
Rep 5,140
Here is two members with 20" F10 wheels, the offsets and the tire widths is exactly the same as on 19".
20" style 356 and 373 for F10: F: 8.5x20" ET33, 245/35-20 R: 9x20" ET44, 275/30-20 F30 335i with 20" oem style 356 Gorgeous: f30.bimmerpost.com 328i Msport with 20" style 373M on HR sport: f30.bimmerpost.com |
08-29-2014, 12:28 PM | #4 |
Now in the dark side !
65
Rep 1,136
On 20" wheels, the closest match for front and rear tires are:
F 235/35R20 - 26.48" R 275/30R20 - 26.50" This is the exact setup I'll have on my car. The 245/35R20 are 26.75" high, original 225/40R19 (on my car) are 26.09" Usually, I don't exceed +- .5" (about 2% difference, depending on tires size) For the 19" wheels: Original: 225/40R19 - 26.09" F 235/40R19 - 26.40" F 245/40R19 - 26.72" R 275/35R19 - 26.58" Seems like the F245 - R275 are closer (by 0.04") on 19", but the front will be slightly higher (.14"). To calculate tire ratio: 245 (width of tire) / 40 (tire height ratio in%) R 19 (size of wheel) (width of the tire) / 25.4 (to convert in inch) * o.(tire height ratio) * 2 (adding the lower and upper sidewall height) + (size of wheel) 245 / 25.4 = 9.65 9.65 * .40 = 3.86 3.86 * 2 = 7.72 7.72 + 19 = 26.72"
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
08-29-2014, 07:38 PM | #5 | |
103
Rep 335
Many thanks to those who responded. Since the 245/40/19 and 275/35/19 combination are a couple percent taller than stock, would I be OK going with a square setup of 255/35/19 on the 8.5" ET 33 wheels? Those tires seem to be almost the same as the OEM diameter. Of course I'm open to any good ideas.
08-30-2014, 04:43 PM | #6 |
65
Rep 1,136
Dunno, and maybe others have done it, but isn't 255 too wide for the front ?
08-31-2014, 07:27 AM | #8 |
103
Rep 335
I found a year-old thread where a couple of guys were running 255/35-19 and 245/40-19 both square. The latter was on an xdrive...245/40-19 is the OEM square setup on the F10 xdrive.
http://f30.bimmerpost.com/forums/sho...d.php?t=866093 In this thread, the OP had 245/40-19 on RWD, but followed up with a report of a little rubbing. http://f30.bimmerpost.com/forums/sho...d.php?t=851622 IMO, the 225/40 OEM tire shown below looks a little stretched on the 8x19 wheel and the wheels I'm considering are 8.5". It appears that 235/40-19 is only marginally larger than stock diameter at 26.4". If that's workable, I wouldn't mind filling up the xdrive tire gap a bit. So many tire sizes, so little time. |
09-01-2014, 01:18 AM | #9 |
39
Rep 38
09-01-2014, 10:19 PM | #10 |
65
Rep 1,136
Did it rubbed at all with this setup ?
And on the picture, any drop or stock RWD height ?
09-02-2014, 01:19 PM | #11 |
39
Rep 38
08-11-2017, 01:47 PM | #13 |
107
Rep 884
Resurrection...Any chance you can post more photos? (assuming you are still a member, etc...)
Current: 2021 Carbon Black w/Cognac X5 M Sport
Sold: 2018 Dark Graphite 540i M Sport Sold: 2013 Mineral Grey 335i M-Sport Sold: 2010 Sapphire Black E90 335i |
