Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      08-28-2014, 10:11 AM   #1
F82FTW
75
Drives: 17' M3 ZCP, 88' M5 Blk/Blk US
Stock Brakes Severe Let Down...
I was stoked for these brakes after all the raving reviews and all of these press track days that seemed, or were advertised, to have gone off without a hitch.
However, fast forward to the real world, and after ONE track day, all four rotors are completely warped and useless...and pads are destroyed.
Now, I kind of expected the pads to be gone, let's be real. BUT, rotors to be destroyed after 6 20 minute sessions?? On an $80k ///M car? Really?
My 135is with BMW Perf front rotors and little else never had one rotor issue after 5-6 track days of hard driving.
I understand track driving is going to net increased wear on your car, but I would have expected a LOT more out of these stock components. Seems BMW engineered these steel brakes to be exponentially inferior to the massively expensive CCB's...
F80 M3 ZCP - Current...E28 M5 1/30 Blk/Blk US Spec - Current...17' 911 - SOLD...E90 M3 - Sold...F82 M4 - SOLD...F02 750Li - SOLD...Austin MINI - SOLD...E82 135is - SOLD...E89 Z4 - SOLD...F10 535i - SOLD...E30 325is - SOLD
      08-28-2014, 11:04 AM   #2
CanAutM3
CanAutM3's Avatar
21105
Drives: 2021 911 turbo
Your rotors are most likely not warped at all. You probably have bad pad deposit on your discs that is causing shudder.
Stock pads on the iron rotors will not handle the heat at the track and will smear uneven deposits on the rotors. Install new pads and the shudder will likely go away after 2-3 weeks of street driving.
It has been discussed in various threads, track pads will likely be needed with the iron rotors for any serious tracking.
Appreciate 6
      08-28-2014, 11:17 AM   #3
drob23
drob23's Avatar
50
Drives: S4
Here's a good article backing up what CanAutM3 said:
http://www.stoptech.com/technical-su...nd-other-myths
UNDRSTR
davem3fan185.50
      08-28-2014, 12:49 PM   #4
F82FTW
75
Interesting stuff indeed, and I do appreciate the input. However nonetheless, the rotors were measured and confirmed warped, both mathematically and visually.
The brakes are just the tip of the iceberg too; I could go into a whole thread about the let downs this car has provided from one track day...but quite simply, I do not have the time.
Massive disapointment in many ways.
At least it's a really fast street car which at least looks like it could handle a racetrack...
      08-28-2014, 01:14 PM   #5
Sir Loin
M3AT LOVER
Sir Loin's Avatar
322
Drives: Silverstone F80 M3
You mean they are confirmed mathematically and visually just like that stoptech article says?
When a driver reports a vibration under hard braking, inexperienced crews, after checking for (and not finding) cracks often attribute the vibration to "warped discs". They then measure the disc thickness in various places, find significant variation and the diagnosis is cast in stone.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
SpeedN866.00
      08-28-2014, 01:33 PM   #6
pfl
113
Drives: Some slow cars
That sounds just like the E92 brakes and how horrible they were for track use. I'm sorry to hear you ran into this on the F82.
      08-28-2014, 01:35 PM   #7
FTS
Enjoying driving
FTS's Avatar
388
Drives: 645
I doubt any iron disc will become unusable after such short period of time, although anything is possible, I would imagine after you replace your pads, some clean up driving hopefully will be sufficient. Best of luck.
      08-28-2014, 01:45 PM   #8
drob23
drob23's Avatar
50
Drives: S4
Aren't the rotors 2 piece floating? Seems really curious that all 4 would warp in 1 track day, especially considering how little the rear brakes contribute. Sounds more like pad material deposits.
UNDRSTR
SpeedN866.00
      08-28-2014, 02:00 PM   #9
CSBM5
CSBM5's Avatar
2696
Drives: 2019 M2 Comp, 2011 M3, etc
It has nothing to do with your rotors as others have pointed out. You used street pads at the track and exceeded their MOT resulting in severe pad material deposition on the rotors (creating the "warped" rotor measurements). This will happen on just about any street car with street pads. If you have put some PFC08 or PFC11 pads on prior to the track session, you could have partied all day without issues.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
Appreciate 4
      08-28-2014, 02:06 PM   #10
F82FTW
75
I appreciate all the input and the Stop Tech article is very interesting and eye opening indeed. It's entirely possible my dealer is completely retarded.
Nonetheless, I'm concerned with the unavailability of any track pads at this point and also completely unsure as to the proper process for mitigating this 'deposit' problem, assuming that is indeed the issue.
      08-28-2014, 02:11 PM   #11
FTS
Enjoying driving
FTS's Avatar
388
Drives: 645
Apparently track pads are available, check post #18: http://f80.bimmerpost.com/forums/sho....php?t=1022435
To avoid warping you need to bed-in the brakes, check stoptech site for simple procedure.
      08-28-2014, 07:10 PM   #12
JoeFromPA
1791
Drives: '15 AW M3 6MT Stripper
What a great thread with various knowledgeable folks calmly repeating sound advice.
I was fairly concerned coming into this thread. Now I feel warm and fuzzy again
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
      08-29-2014, 08:04 AM   #13
AMPowerJ
One mod leads to another ...
AMPowerJ's Avatar
415
Drives: 2014 F10 M5
smh
Although I am fairly certain this will be a good track car, it's not suppose to be a track car out of the box. It isn't a GT3. It does many things a true track car can't do. As for your brakes, I'm sure they are fine like all the others have stated.
I have friends running in the A groups using stock E90 M3 brakes for years with just track pads that don't have warped rotors.
After your track session did you keep your brake pedal depressed for an extended period of time and/or use your e-brake?
Current: 2014 F10 M5
Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3
      08-29-2014, 08:43 AM   #14
CanAutM3
CanAutM3's Avatar
21105
Originally Posted by AMPowerJ View Post
... and/or use your e-brake?
Just as a tidbit, using the e-brake should not make a difference for pad deposit on the discs because the e-brake on those cars is an independent drum/shoe setup inside the rear disc hubs.
      08-29-2014, 08:56 AM   #15
AMPowerJ
AMPowerJ's Avatar
415
Drives: 2014 F10 M5
Yeah I know and thought about that as I typed but I still don't use mine as just a good practice.
      08-29-2014, 09:28 AM   #16
MaynardZed
MaynardZed's Avatar
1231
Drives: wife crazy
smh
I'm guessing he knows better than to put the e-brake on with hot rotors.
I'm headed to the track this weekend with my new M4. I don't plan on pushing it real hard maybe run 7/10 on just 2-3 20 minute sessions. It will be a second car for me, but I'll report back if I have any problems with light track use. Stock steels and pads too for me.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      08-29-2014, 09:28 AM   #17
M3 Esq
Automobilist
M3 Esq's Avatar
395
Drives: E70 X5, 911 GT3
OP, are you doing a cool down lap before coming into the pits? That will help. Also, what kind of brake fluid are you running? Agree with the others that a good set of high temp brake pads will help too.
      08-29-2014, 09:31 AM   #18
Floridagator
Obsessed with braking
39
Drives: 2015 BMW M3
2015 BMW M3  [0.00]
This is a subtle comment, but it's important!!
If you're coming in from a track session ESPECIALLY with stock pads which are already susceptible to lining transfer, DO NOT leave your foot on the brake pedal with the car stopped, even for a second. You'll leave a big imprint of pad material on the disc which will result in vibration your next time out.
The comment about the e-brake was simply to suggest using the e-brake (lightly) to hold the car rather than sitting in the pits with your foot on the pedal. Alternatively, wheel chocks in the pits are a good idea.
      08-29-2014, 09:38 AM   #19
Floridagator
39
Drives: 2015 BMW M3
2015 BMW M3  [0.00]
Another good comment.
Despite the all the track-based marketing we see, most cars are not perfectly-suited to racetrack use straight from the showroom floor. This is especially true of brakes, where manufacturers will ALWAYS prioritize [low] noise/dust/wear over outright track performance. If you read the M3 manual, the ONLY thing specifically mentioned in the track use section is that the brake pads aren't suitable for tracks. Should any of us be surprised when the stock pads don't work particularly well in this environment?
The Porsche GT3 RS may be the one exception, where the stock car is running a variation of Pagid RS19 from the factory.
It's been mentioned several times, but anyone taking the car to the track should seriously consider the BMW Performance pad kit, or one of the offerings from Pagid (RS19/RS29).
      08-29-2014, 10:27 AM   #20
Mandi90TT
2712
Drives: BSM 6MT M4 F82
Yeah, just going to go with this, with a caveat is not that your dealer is retarded, but they are unused to dealing with something outside the boundaries of normal. Hot pad deposit on rotors is outside the bounds of normal for everyday driving. Very few people actually track their cars, and the ones that do, usually know enough to use seperate track pads.
Anyways, as others have said, get a new set of pads on there, perhaps driving for a week or two with track pads on to remove the deposits, and then back to regular street pads.
Final comment: a set of chocks at the track is always good to have, for multiple reasons, including this one.
Final final comment: if you did, indeed, warp all four rotors from one track day (which I highly doubt), your experience is far outside the experience of others who have tracked their M4. If true, you might want to consider your braking habits as a possible culprit (not meant as an insult, just a suggestion)
Last edited by Mandi90TT; 08-29-2014 at 10:28 AM.. Reason: One more comment I forgot
      08-29-2014, 10:59 AM   #21
consolidated
consolidated's Avatar
205
Drives: F80 M3
I recently had PFC race tech help me with a brake issue on my spec racecar. Here's the back and forth, pertinent info underlined. Your rotors can take the heat, the pads however couldn't. Race pads on even the stock steel rotors should put your face thru the windshield. I use PFC, sometimes Pagid. Also keep in mind if your using DSC, it's modulating your brakes and putting heat into them you may not even be feeling.
I instructed at COTA for a Ferrari event last year, the pits had a line of F cars getting their rear brakes worked on. Some drivers were using traction/stability control as a total crutch, pads were melting, fluid was cooked, smoke coming from their CCBs, horrible driving. These were 458s and piggy Californias, the older cars no problem.
1. With the knockback, does the class allow 2-piece discs?
Only OEM cast one rotors piece allowed
2. With sealed bearings in the hubs, does the preload go away when the car comes in from the race track?
Unsure, however one bearing is starting to make noise when cornering and may need to be replaced.
3. We need to get the discs, pads painted up and the calipers stickered up so we aren’t so blind as what’s really going on here.
I've ordered ti barriers, caliper stickers and temp indicator paint to get data.
4. Brake pad Ti thermal barriers can be purchased from http://hardbrakes.com/
5. Discolored brake fluid means the caliper’s bulk temp is in excess 190c. 210c is the limit for the seals. It’s likely time to refurbish the calipers.
Planning on doing this.
-Brake fade is when the pedal is hard, but after a period of time the braking efficiency starts to diminish.
Not getting this
What brake fade is when the system gets hot enough to cause distortion or compressibility or something in the hot end of the brakes becomes thermally instable like the brake pad. (08 compound is good to 800c which is 150c higher than the iron in 1-piece OE disc) This instability causes non uniform distribution of the friction materials and the end result is a loss of brake efficiency. (In layman’s terms, the car losses stopping power for the same effort over time)
-going over center on the brake pedal and loosing mechanical advantage, effect is soft pedal and lost efficiency.
-aggressive "jump in" from the initial apply and the ABS strategy implements a "preemptive mode" and pulls pressure out of the system there by reducing "bite" in an effort to maintain threshold tire grip,
Help me understand please
There’s a 1.5hr technical seminar I do for PCA, Porsche’s Tech Tactics, SCCA National convention, Performance Racing Industry and David Murry Trackdays that covers this. We will have a video on this but it’s a huge amount of work to edit it so it’s not on line yet.
I will be in Austin for the IMSA/WEC race Sept 15-21, 2014.
Darrick Dong
Director of Motorsports
Performance Friction Brakes
ddong@performancefriction.com;
F80 M3 / Mineral Grey-Silverstone / CCB
      08-29-2014, 11:39 AM   #22
CSBM5
CSBM5's Avatar
2696
Excellent point about people using DSC/MDM mode on the track as it makes serious use of rear brakes, individually (fronts also), and puts a huge additional load into the braking system. If you're driving at a serious and competent level, you should not need a nanny since all the nanny does is help an inexperienced driver create bad habits in addition to unneeded brake loads.
Note the #4 above. I've been using Ti shims for 10 years, and they are essential to preserving your piston dust covers and seals -- especially when the pads are worn down below 1/2 thickness, etc. The pad material is an outstanding insulator, so when its thickness is reduced as they wear, backing plate temperatures (and therefore heat transfer into the pistons) goes up proportionally.
With three simple things, I'm sure the F8x brakes will work wonderfully and provide good service life:
1) PFC/Pagid/etc race pads
2) Motul 600 or equivalent high temp DOT4 fluid
3) Ti shims
I guess the 4th item is to not drive the car near its limits for extended sessions if you're having to use stability control; if you are going to do that, I'd recommend using Ti shims in the rear also.
Cheers,
Chuck
Current Stable:
Search this Thread:
Advanced Search
f80post
