E90 Software Updates Listing
01-03-2006, 07:57 PM | #1 |
E90 Lover
Rep 8
Is there a list of the software updates for the E90 and what they addressed with each update? I'm curious and I can't find anything. I dropped my E90 off and was told they had a software update "recall" pending on mine. I'd like to be able to find out what it affects in my car.
Thanks in advance!
'06 325i, SG, Siruis, Pwr Seats, Auto, etc..... :rocks:
'99 328i, White, Premium, Sport, Park Assist, 5spd, etc.... |
01-04-2006, 03:03 AM | #2 |
1312
Rep 10,185
Ive posted them here before
If you have a pre-september 2005 built car they dealer must upgrade it to the latest software when the car comes in for its service because there is a slight glitch causing some cars to give false warnings. A few early cars also wouldnt allow 3rd party diagnotic equipment to connect to the car, and the newer software fixes that problem |
01-05-2006, 12:57 PM | #3 |
E90 Lover
Rep 8
Thanks for the info. I tried a serach but for some reason, I couldn't find it. I'll try again.
01-05-2006, 01:53 PM | #4 |
1312
Rep 10,185
This is basically it
The following software errors were corrected with the release of Progman 20.00.01 (Target data Status E89x-05-12-510). Unable to Pair or Reconnect a BluetoothÃ’ Handset to a Vehicle. The following software errors were corrected with the release of Progman 20.00.00 (Target data Status E89x-05-12-500). Engine juddering/idle speed surging when it is cold. N52 engine. No customer complaint. The following faults are stored in the JBE (Junction Box Electronics) erroneously. The JBE must be recoded to correct these faults. Door Mirror Heating Left – 0xA6DE Door Mirror Heating Right – 0xA6DF The fuel gauge reading is incorrect. The fuel gauge indicates higher than the actual amount in the tank. The following software errors were corrected with the release of CIP 19.01.00 (Target data Status E89x-05-09-530) CCC (Car Communication Computer) poor AM reception. The audio keeps playing if the vehicle is switched off for up to 3 minutes (until vehicle enters sleep mode). The audio cannot be switched off with the rotary knob. Only vehicles with CCC (Car Communication Computer) are affected. Teleservice: no service calls even though CBS services due. Only vehicles equipped with SA639. Loss of airflow from defroster vents. After repeated convenience opening and closing using the remote key, only the trunk lid locks and the doors remain unlocked. CCC (Car Communication Computer) equipped vehicles with telephone, call fails when dialed using linked sequence ("p" for pause) stored phone numbers. Sporadic CCC resets (screen blanks out briefly and CCC restarts). The outside temperature display in RAD2 (BMW Professional radio) does not display any temperatures above 85 deg;F. I-Drive Controller does not function. Central Controller High (ZBE) FC E2C7 "Bus Communication Fault" is stored. The "ELV (Electric Steering Lock) malfunction", check control message may be displayed intermittently when the driver attempts to start the engine. It is not possible to start the engine for 16 minutes unless the vehicle has entered sleep mode. The "Anti-trap protection deactivated" check control message is displayed during one-touch closing of the rear power windows. The window then can only be opened a little when the one-touch opening switch is pressed. While traveling at a slow speed with a constant rain, the automatic wipers do not operate. Rear window roller sunblind does not rewind in low temperatures. After a jump start (battery dead), the adaptive headlights turn briefly to the right without the customer turning the steering wheel, then return to the center position. Vehicles with SA 524 (Adaptive Headlights) produced from 5/31/04 to 8/30/05. Menu button on the iDrive Controller flashes briefly. Vehicles with SA 609 (CCC-Navigation). After the automatic parking function is deactivated (by disengaging reverse gear), the passenger's side mirror does not return to its original position but to the mirror setting stored with the key used. If comfort opening was cancelled (if all the windows are already open) and is then reactivated, intermittently the sunroof does not open until after 4 seconds instead of the normal .5 seconds. Vehicles equipped with SA 322 (Comfort Access) FC "A0AC TAGE3_ antenna defect" may be erroneously stored. After programming the vehicle the system should be checked for proper functionality. If fault code returns perform DIS test module.
BMW if you are reading, I need a job, Please. |
01-05-2006, 02:05 PM | #6 | |
1312
Rep 10,185
But we are still waiting for someone with Pro Nav to get CIP20 so we can see if it adds MP3 support
01-05-2006, 02:37 PM | #8 | |
1312
Rep 10,185
What we need to find out is if it allowes pre-september cars to play MP3
01-05-2006, 03:01 PM | #9 | |
THE Viv
185
Rep 4,743
Drives: 330i SE
07-21-2006, 07:48 AM | #10 |
Rep 37
How do I figure out what version I have? I have gotten the ELV warning once, but the car was already started (if I recall correctly), and it went away after about ten seconds. I just got the car at the end of June, and it just arrived from Germany three days before that. How do I find out what my build date was?
Brien |
07-21-2006, 09:52 AM | #11 |
13
Rep 548
I wish they would update other things too, namely:
- When the Air Recirculation is ON (not Active-ON, but full recirc.), it turns off when you restart the car. You have to push the button to bring it back to the on setting. - The headunit has no memory of when you have an MP3 disc in the Professional headunit in "Current Track" mode, which displays the ID3 tag of the MP3, and/or in "Random Track" mode. Every time you restart the car, you have to go through the button-pushing sequence of "random", and then "list" and then "current." Why can't it just remember where it left off? |
07-21-2006, 09:55 AM | #12 | |
Freude am Fahren
336
Rep 5,254
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
07-21-2006, 10:45 AM | #13 | |
1312
Rep 10,185
They will never do that, since it is a safety feature People need oxygen
07-21-2006, 01:35 PM | #14 | |
13
Rep 548
07-21-2006, 01:41 PM | #15 |
Black Sapphire 330i
32
Rep 362
Safety? Come on - has anyone - ever in the history of automobiles - accidently died from a lack of oxygen because their car was in recirc. mode? LMAO. Our Mercedes has the push button recirc and it stays on all the time. 4 hour road trip and we don't die or even get tired.
Please, if you die from something like this, I would chock that up to Natural Selection. |
07-21-2006, 03:22 PM | #16 | |
1312
Rep 10,185
Legislation requires them to have the system turn on full circulation every certain amount of minutes automatically, it would then return to circulation after a specified time. Also, I never said anything about dying, but if you would like to experience or see some of the effects of high carbon dioxide or low oxygen levels, I recommend you find a lab or agency or Air Force medicine centre with a altitude test chamber that can simulate these conditions for you. You would be surprised to see what effects there are
07-21-2006, 04:35 PM | #17 |
Black Sapphire 330i
32
Rep 362
So, when you said safety, you meant what exactly...
Honestly, I do not speak from authority. Maybe the reason we don't get sleepy in Merc w/recirc is because it does let in a 'legislated' amount of 'periodic' oxygen. As an ex-airforce pilot, I'm well aware of oxygen deprivation. Driving w/recirc has absolutley no resemblance. So, if you run a car in the car in a garage, windows closed and recirc On, you're saying you will still eventually die of carbon monixide? Since the car is 'legislated' to bring in outside air? I heard a standup comic do a blonde joke on this once... |
07-21-2006, 04:56 PM | #18 | |
1312
Rep 10,185
Id have to check the BMW training manuals when I get back home to make shure on the times. Manuals say its a EU legislation requirement. Carbon Monoxide is a very bad gas and you dont easily realize its affecting you ( until you see yourself on video afterwards, but not quite as funny as hypoxia training )
