Fault Code 2EA1H/11937
08-26-2014, 04:33 PM | #1 |
81
Rep 834
Drives: 15 Subaru Outback 3.6R Limited
Took the E90 to my independent mechanic for a door lock actuator install, oil level sensor replacement and an oil change yesterday. This morning I get the red Service light followed by the red triangle and exclamation mark. After work I stop back by the mechanics to inquire and his scan tool shows fault code 2EA1H/11937, but it has no description and neither of us can find out what it is related to. After resetting the error and restarting the car the error returns.
Does anyone here have any knowledge of this code and or what it means? Thanks!
After enjoying 9 years with my BMW I am now Back in a Subie: formerly Mi330xi Last edited by Back in a Subie; 08-26-2014 at 04:45 PM.. |
08-26-2014, 08:59 PM | #2 |
17309
Rep 18,733
I just went through my Bentley manual yesterday looking for a fault code on my car and I don't remember seeing a 5-digit BMW code like that one. I have replaced the oil level sensor however. Did the mechanic reinstall the ground plate and grounding wire?
Does the CBS give you an oil level? I'll try and remember to check the Bentley for that specific code tomorrow. |
08-26-2014, 09:18 PM | #3 |
Gateropode
329
Rep 2,848
A quick google on your issue pulls somethign very relevant Seems you need to code the sensor.
http://www.e90post.com/forums/showthread.php?t=600773 |
08-28-2014, 03:23 PM | #6 |
81
Rep 834
Yeah, I see no mention of needing to code the sensor in the DIYs that I have found, but the fault persists. Whereas in a couple other threads, such as the one linked above, dealerships have supposedly said that it does need it...
So, I am taking it back in on Friday after work and we will see what he can do.
After enjoying 9 years with my BMW I am now Back in a Subie: formerly Mi330xi |
08-28-2014, 08:00 PM | #7 | |
17309
Rep 18,733
08-29-2014, 10:59 AM | #8 |
81
Rep 834
I had no fault codes but the sensor would trip intermittently telling me I had min oil level, then right back to normal on next refresh. The oil level currently reads min and it says "inactive" above that.
08-30-2014, 05:39 PM | #10 |
Gateropode
329
Rep 2,848
I have no more information than what I found digging the internet. The fault code is the same, and it also discuss a problem with that sensor, so that seems relevant, but that's all I know about it.
08-31-2014, 08:16 AM | #11 |
17309
Rep 18,733
It could be the 335i uses a different sensor and comm protocol than the N52 (my car). The link you posted was for a 335i; my experience is with the N52. Maybe we are both correct. The sensor is pretty simple, just a concentric capacitance tube, I can't see how it needs to be coded in order to make it communicate with the ECU, but you never know. All I do know is when I changed mine, it communicated fine and didn't change the (programmed) behavior of the CBS issue I was trying to solve and it has been reporting oil level consistently since I installed it a year ago.
09-08-2014, 10:40 AM | #12 |
81
Rep 834
Ok, for anyone interested in the end result of all this. My indy mechanic couldn't figure it out so into the dealership I went. They couldn't get the sensor to talk to the car either so they removed and replaced the sensor and it worked. Their diagnosis was that it wasn't plugged in enough.... sigh.
Tags |
2ea1h/11937, error code |
