M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      08-25-2014, 03:43 PM   #1
Ray knight
234
Drives: LBB F85 X5M
So i have a big old hole in the bottom of my airboxes. I've read that the block off plates will improve power but what about the snorkel in the newer cars? I want to have my dealer get me one or the other but which is better? Also, has anyone just duct taped the hole closed instead of spending $300 on factory plates? Or riveted on a piece of plastic?
      04-15-2015, 07:19 AM   #2
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
+1 on this!!
      03-12-2016, 10:52 PM   #3
Rearview
65
Drives: F10 M5
Left mine open as i can see evidence of water being sucked in and draining out. Yanked out charcoals.
      04-10-2016, 12:04 AM   #4
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1083
Drives: 2018 RS3, 991 Turbo
Don't block with plates....
      05-04-2016, 09:19 AM   #5
lunden
32
Drives: BMW M6 F13 800RR
I blocked it..
      05-14-2016, 06:34 PM   #6
TheHouseWon
TheHouseWon's Avatar
643
Drives: 2013 M5
Why not? Because it prevents potential water from draining?
I had snorkels and rid of them, have a hole now. Without the snorkels the spool sound is a bit more evident.
      05-24-2016, 04:21 PM   #7
harry007
29
Drives: White M5 F10
Spool sound maybe better, but using blanking plates is more affective. No heat getting in. Im not sure what water would get it.
Use rpi front scoops and you will get a good flow of air straight to your intakes.
function over image and sound anytime. Were dealing with an almost 600bhp engine. Do it right, do it properly.
      06-18-2016, 10:05 AM   #8
edysinger
I Calibrate Engines
15
Drives: BMW M5 IB/CL
I taped mine off as a test after removing the snorkels. I taped inside and outside of the airbox to maximize bonding area. After 2 weeks and a couple of WOT runs i checked on the airboxes and both sides had the tape pulled away on one side of the hole. This would initially seem to me the hole is needed to allow enough airflow (maybe not enough) through the cold air side of the airbox.
      06-21-2016, 10:14 PM   #9
ur20v
184
Drives: F10 M5
These have two functions - to stop you swamping the engine in deep puddles and heavy rain also allow additional air flow.
As I have tested temps, in front of the OEM air filter feed pipes by the radiator, in the air box and in the engine bay, you will gain nothing from blanking them - also turbo cars are not as IAT sensitive as NA cars.
Scoops and blanking the air box will do nothing for these engines, changing to a dual cone filter set up will help spool up time and gin some performance once you tune the engine but only in the region of 10 bhp which you won't be able to feel or measure against a stop watch- does get you a bit of turbo spool / induction noise though which might make it worth your investment...
Search this Thread:
Advanced Search
m5post
