JB4 setting for going to dealer
08-22-2014, 03:20 PM | #1 |
Rep 26
I brought my car in today to get my new battery programmed and I left my jb4 connected and on map 2. the dealer said that they were unable to communicate with my computer...I was wondering if the jb4 is blocking it and if so can I just put it on map 0 or does it have to be removed? I switched from a lead acid to agm so I have to get it done. thanks in advance
08-22-2014, 03:54 PM | #4 |
44
Rep 394
08-22-2014, 03:57 PM | #6 |
BimmerPost Supporting Vendor
24198
Rep 190,805
We recommend you completely remove it before dealer visit.
Remove it before your dealer visit, the light wont pop up until 40~50 miles.
08-22-2014, 04:13 PM | #7 |
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
If you leave it in Map 0 you can take it in. It takes some miles or time before it shows the CEL.
08-23-2014, 05:37 PM | #10 |
enthusiast
117
Rep 997
Drives: 2011 e92 lci 335xi
clear codes/ remove jb4 or if its simple maintenance and you aren't throwing any other codes leave it in map 0 so yes to answer your question the jb4 is blocking the obd port access. in map 2 at least
08-23-2014, 06:03 PM | #11 |
136
Rep 1,192
Drives: 2011 335i MT
Map 0 is the "passthrough" mode. Some have reported taking their car to the dealer and the dealer no noticing the JB4 while in passthrough mode. However, I'd clear the codes and then remove the JB4 before taking it to the dealer.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
08-23-2014, 08:09 PM | #12 |
324
Rep 2,014
Good advice in this thread
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
08-28-2014, 10:23 PM | #13 |
Nurburgring
Rep 67
JB4 at Dealer Remove it
I had mine in a couple of times for routine oil & maintenance cleared codes and set at 0 with no issues, but the passenger seat heater went out and the tech had to re -program the module. He found the JB4, unplugged everything
and it PUT the DME in permanent LIMP mode. I had to fork over $2000 for a new DME and it took a month to get one from Germany. I highly recommend you remove it or at least unplug everything with the battery disconnected! |
08-29-2014, 09:00 PM | #14 | |
Rep 85
09-01-2014, 04:46 PM | #15 |
Nurburgring
Rep 67
They called me to say they could not clear a check engine light and I thought no big deal, on the way home it was in limp mode and my SWC was not working, when I went right back and said it was undrivable and that's when they said the tech found all the extra wires and disconnected them all and hooked up the stock wires. I called Terry and he thought by hooking jb4 back up I could clear the code, but there was a code in the DME that I could not clear. and it stayed in limp mode.
So I completely removed the entire JB4 took it back to the stealer and after a couple more days of diagnosis they said the only way to fix was replace the DME, since I bought the car used and am over 50 I said I did not know anything about it and said my car was perfect before you guys messed with it but they were not buying it. The irony is I actually emailed Mike from Roundel before I took it in and he said it should be no big deal to leave it on in the stock mode, but at the end of the Day Mike, and Terry left me hanging and the dealer actually took $650 off the DME and I used their X5 while we waited to get the new DME. It's out of warranty now so I doubt I'll EVER take it to a dealer again unless it's something an independent can't fix but I sure hope no one else has to go through such an ordeal! |
