JB2H Dyno Results: 326whp/354wtq **UPDATED** Video's & Pics
12-19-2007, 05:44 PM | #1 |
192
Rep 2,443
Just got back from the Dyno. I am in a hurry right now, so i can post the full review/results until later when i have more time.
Here are the Overall run numbers: DynoJet SAE Numbers*** All runs were on 93oct. 2nd Cat Deletes, and JB2H Run 1: with ITG Filter - 318whp/348wtq Run 2: with ITG Filter - 312whp/348.6wtq Run 3: Stock Filter/Open Box - 324.7whp/345.8wtq Run 4: ITG Filter/Open Box - 324.1whp/346.3wtq Run 5: Stock Filter/Closed Box - 326whp/354wtq Run 1: with ITG Filter - 318whp/348wtq Run 2: with ITG Filter - 312whp/348.6wtq Run 3: Stock Filter/Open Box - 324.7whp/345.8wtq Run 4: ITG Filter/Open Box - 324.1whp/346.3wtq Run 5: Stock Filter/Closed Box - 326whp/354wtq <-- Best Run with stock filter Videos are on there way!! Last edited by AU335; 12-24-2007 at 11:06 PM.. |
12-19-2007, 09:50 PM | #4 |
Perf BMW mag issue 147, 159
414
Rep 6,803
interesting numbers with the stock/itg filter... strange
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
12-19-2007, 10:51 PM | #5 |
192
Rep 2,443
12-19-2007, 11:41 PM | #7 |
192
Rep 2,443
12-19-2007, 11:49 PM | #8 |
96
Rep 2,587
I'm sure they screwed it up, most shops don't know how to dyno an auto. See if they can email you the .drf files, or what I always do is bring a USB key to bring the files home with me. I'm curious what your numbers look like in STD.
12-20-2007, 12:10 AM | #9 | |
192
Rep 2,443
FWIW, what do you expect/guess the STD numbers to be? just wondering |
12-20-2007, 12:11 AM | #10 | |
96
Rep 2,587
12-20-2007, 10:39 AM | #11 |
انا خارج الكلبه
Rep 401
I'm going to try and hit the dyno again today...my numbers were lower on the Hotpill and 93 octane. I think I made 330 rwhp on the R switch w/ 96 Oct. I left my dyno graphs in Blakes toolbox! I have to go back today to get one of the Mustangs tuned on Nitrous. Should be interesting.
12-20-2007, 10:53 AM | #12 |
327
Rep 4,484
I'm just wondering if all the filter swapping with open and closed air box lid fudged the numbers.
You should of just swapped the filters and left the lid closed on all the runs. The ECU was probably so confused with the amount of air coming in from having the lid on, then off, then put back on. It doesn't make sense that your highest run would be with the stock filter and the lid on. And it be significantly higher than the first runs with the lid on, and even higher than the runs with the lid off, and measurably more torque too. I personally think your ECU was drunk by the last run. |
12-20-2007, 11:02 AM | #13 | |
96
Rep 2,587
Bring a USB key and copy your .drf dyno files to it so I can check out the runs! |
12-20-2007, 11:52 AM | #14 |
148
Rep 5,389
Very interesting dynos...thanks. Now I know why I just ordered the BMC Air Filter to replace my ITG Air Filter. Or maybe I should just put my oem stock paper air filter back in? Ha ha.
btw -- congrats...those dyno numbers are very decent; similar to the PROcede v1.47 with a little less RWTQ.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
12-20-2007, 11:56 AM | #15 | |
192
Rep 2,443
12-20-2007, 12:13 PM | #17 |
192
Rep 2,443
Stock filter for now. I am definitely not saying the ITG filter doesn't perform well, but just since the recent dyno's I'm going to stick with the stock and maybe even try out the BMC filter.
12-20-2007, 12:20 PM | #18 |
50
Rep 1,600
Drives: e90 335i
Great numbers!! Car looks real strong. On the filter issue, it seems to me the only meaningfull measure would be flow accross the filter fitted in a stock box simulator. I know streamline did this type testing so at least you knew the product flowed with less restriction than the stock filter. Whether or not that lead to measurable gains would be unclear. Gains or losses are so small that they overlap the standard deviation normally seen from run to run. I believe one member ran at the track with the stock filter and then with no filter and the trap speeds were unchanged
On an aside, Terry, is it possible to come up with a way to run the H serially with the R switch so that it would only be on when the switch was on, or would that require making a different R switch with the extra .5 PSI boost? |
12-20-2007, 12:22 PM | #19 | |
96
Rep 2,587
12-20-2007, 12:22 PM | #20 | |
327
Rep 4,484
If you do this test again, do it with all the filters, but always have the lid on. |
12-20-2007, 12:27 PM | #21 |
50
Rep 1,600
Drives: e90 335i
Exactly I'm wondering if I can just plug it into one of the wires upstream from the switch and wham! another half PSI boost next time I go to Irwindale.
12-20-2007, 12:28 PM | #22 | |
327
Rep 4,484
I did about 332 rwhp and 366 rwtq on v1.47 with the stock air filter and lid closed, but on a slightly lower octane (92) and with my 2nd cats still in place. With the K&N drop in it was 336 rwhp and 368 rwtq. But I agree with Terry, had he been in STD mode, he probably would of seen around 332-334 rwhp and 355-358 rwtq. |
