08-20-2014, 03:51 PM | #1 |
459
Rep 935
Tire fitment and size question
Hi , I just got my HREs installed on the car and compared to the OEM 19s wheels, the tires seem much stretched in the rear..
Does this look like the rear wheels should be paired with wider tires??I used to run 295 in the rear on E92, it worked fine, guess i should also go 295 for the M4 too ? Here's the front , the tire fits fine with a flatter sidewall [IMG][/IMG] However, the rear tire seems much more stretched than it was on stock wheels. [IMG][/IMG] |
08-20-2014, 04:08 PM | #3 |
459
Rep 935
08-21-2014, 11:15 AM | #4 | |
450
Rep 4,592
For reference : E9x ZCP 19" Wheels (Competition) Front : 19x9 ET31 Rear : 19x10 ET25 F8x 19" Wheels : Front : 19x9 ET29 Rear : 19x10 ET40 As your TireRack fellow said, you might not be able to go wider without rubbing. The more aggressive (Lower) offset on the E9x rears push those wheels out and if you bottom out your suspension, it might take half your fender with it if your tire is too wide. See if you can find your build sheet from your HRE order, and let me know the offset. I should be able to offer some more helpful advice then |
08-21-2014, 12:21 PM | #5 | ||
459
Rep 935
2021 G05 X5 40i-Phytonic Blue
