08-20-2014, 12:24 AM | #1 |
im a car
734
Rep 1,117
Drives: 220i M Sport | 520i M Sport
removing tar spots?
what's the easiest way to remove tar spots from the paint? i've read that there are some products designed specifically for such use but that they'll damage the paint? white car so the spots are really obvious
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB |
08-20-2014, 08:48 AM | #3 |
4516
Rep 8,942
If it's from driving through construction sometimes the township will pay to have it fixed depending on how bad it is, worth checking if that's how it happened.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
08-20-2014, 08:52 AM | #4 |
im a car
734
Rep 1,117
it's nothing terrible, just irritates me when i'm washing the car...was hoping that there was some kind of solution that didn't involve having to re-wax every time after use (as my googling has suggested is necessary)...
08-20-2014, 09:40 AM | #5 |
3074
Rep 5,577
You can spot polish and wax - after hitting the tar with a dedicated tar remover.
Isopropyl Alcohol is good for tar spots but on new paint or in the wrong concentration - may be too harsh. I Had some cosmoline & tar spots and Lucas Slick Mist Spray Wax took the spots out after a wash. So try the mildest product first with the gentlest touch ( no heavy pressure ) and you may find regular polish or wax does the job. |
08-22-2014, 01:02 PM | #7 | |
4516
Rep 8,942
2022 Macan S
08-22-2014, 01:04 PM | #8 |
4516
Rep 8,942
Waxing in general if you're pressed for time hit the hood and the trunk. Those areas take the most abuse and on our cars you're looking at 10 mins max.
2022 Macan S
08-22-2014, 02:17 PM | #9 |
208
Rep 602
BEM-s4 is correct...once you use a "tar removal" product, your wax in those areas are past tense. Clean off the removal residues...as these prods are "oil" based to cut oil and tar.
Once surface is cleaned--wax away. |
