HELP: No sound from radio after rain
08-19-2014, 12:19 PM | #1 |
Rep 3
I have a 2008 BMW 335i convertible (e93) and after the rain I have no sound from the radio so I checked the amp in the trunk and saw that it was sitting in a puddle of water (stupid design for bmw to put the amp under the trunk mat and let water get in somehow) I am wondering if there`s anything I can do to fix this or if I need a new amp and if anyone knows where I can go to deal with this other then the dealer.
(I am located in the GTA area) Any help would be appreciated. |
08-19-2014, 02:58 PM | #2 |
1911
Rep 13,104
There is a lot of this happening now.
The dealer will want 1200 to 2000 to fix this. You need to find out how the water got there or stayed there, and fix that. Clogged Drain lines or Seals are usually the issue. Somtimes you can find a used amp or get the one you have fixed. Three or 4 threads within the last 2 or 3 weeks with the same problem. http://www.e90post.com/forums/showthread.php?t=1022562 http://www.e90post.com/forums/showthread.php?t=1017610 answers in the above links. Last edited by ctuna; 08-19-2014 at 03:06 PM.. |
08-20-2014, 08:13 PM | #3 |
35
Rep 1,068
i've seen amps in the for sale section for about 350$US
but source your leak first.
2006 BMW 325xi E91 Wagon SGM
18" Fast Nemesis / Azentis Staggered Bilstein B12 w/E93 Eibach Pro Kit 2009 CIC Retrofit + Combox 6NR, 6NF, snap-in retrofit |
