V2 problem??
12-18-2007, 08:53 PM | #1 |
Rep 525
V2 problem??
I went on a drive after install and my boost is at 7.6 at idle. when I step on the gass the boost lowers to like -.09 What the heck did I do wrong?? Oh, and no codes?
12-18-2007, 09:21 PM | #4 |
Rep 525
Solved, kinda... Had a wire come off (cold and electrical tape don't mix)... New problem CODE says engine malfunction Reduced power?? check all six ecu conections, they look good, so i went a block a hit the gas Boost shot to 16.7 so I turned around. What the heck is going on?? 1.47 was so easy to install....
12-18-2007, 09:35 PM | #9 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
1) Makes sure you installed the new green loom that came with the v2 upgrade 2) Since you had an open circuit on one of the signals, you threw a code (as you mentioned). No biggie. Just unplug your battery for 30 min and re-test your car. Your code should be gone and your boost should be back to normal. Shiv |
12-18-2007, 09:40 PM | #11 |
441
Rep 18,331
Driver side panel inside of the car near where your left knee...You will see a cover i think says OBDII or something...Plug it in then turn on the ignition button twice but don't start the car, just press the button twice....I think you have wired something wrong...I would go back and check it again...Remember that with this install it requires us to connect stuff to the Procede connectors...I mess that part up too...You have to be careful and get a flashlight to look at the numbers because they are very very small and mistakes can happen!!!
12-18-2007, 09:44 PM | #14 |
654
Rep 10,587
did you datalog them? you have hit start datalog and end datalog to make a file, once you have made a file and saved it, then you can view file under datalog to see your boost/rpm/whatever files.
12-18-2007, 09:44 PM | #15 | |
Rep 525
12-18-2007, 09:45 PM | #16 |
Rep 525
next run I will log them thanks
12-18-2007, 11:06 PM | #17 |
Rep 525
MUCH BETTER, thanks Shiv... I'm still trying to figure out how to pull up my data logs though I did 5 and when I go to "View data log" it opens analysis 1.01 and then I try to "load data set" and I can't find the logs?? Where the heck are they...
I didn't have a wing man so I had to drive and start and stop the logs, but I only ever saw the boost get to 12.7ish??? is that normal?
12-18-2007, 11:11 PM | #18 | |
Rep 179
Try C:\Program Files\Procede\Pde_Reader_v2_0\data
