F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > F32 Water pooling on cowl
GetBMWParts
      08-13-2014, 01:19 PM   #1
kydron
15
Drives: 2014 435i
After washing, there are two spots on the cowl that end up pooling water. I end up having to dry these out by hand after each wash. Can anyone else confirm if these are supposed to drain anywhere?
I've attached a picture of the center part of the cowl. There is a similar spot towards the passenger side that does the same thing.
      08-13-2014, 02:15 PM   #2
simarddominic
simarddominic's Avatar
26
Drives: 435i XDrive M Sport MPPK+MPE
Same for me...I had to open the hood and dry it after all wash...
      08-16-2014, 04:48 PM   #3
JUSTIN808
Drives: 22 X4MC, 22 Ridgeline RTLE.
mine does the same thing
      08-19-2014, 02:36 PM   #4
Fast400
Fast400's Avatar
Germany
679
Drives: iX M60
2014 BMW  [0.00]
Drilling a small hole allows the water to drain. Not sure where it drains on driver side.
      08-19-2014, 03:10 PM   #5
G30 B58
Pace Car Driver
1547
Drives: '22 AW G30 B58 M-Sport
Noticed this on my brothers M4 as well.
      09-10-2014, 02:58 PM   #6
G30 B58
Pace Car Driver
1547
I would expect you guys to be all over this one. What gives?
      09-10-2014, 06:39 PM   #7
FC4
2644
Drives: Yes
Wow. This is unbelievable. Something must be done at once! I'm headed to the dealer and taking this up with the service manager. If they don't buy my car back, BMW North America will be hearing from me!
      09-10-2014, 09:41 PM   #8
ji99lypuff
100
Drives: 2014 bmw 328xi
I did have a recall for a grommet not allowing water to drain but i think this is a different location.
      11-02-2014, 04:04 PM   #9
Dgdoc
Drives: 435 Gran Coupe
Anyone check with BMW or dealer to see if there is a recall for this?
I've got the same problem on my 435 GC.
      11-03-2014, 06:10 AM   #10
G30 B58
Pace Car Driver
1547
If no one else does I'll look at this and fix it over the Winter.
      11-04-2014, 07:37 AM   #11
F32Fleet
F32Fleet's Avatar
3540
Drives: 2015 435i
Correctly me if I'm wrong but isn't it pooling on plastic? If so I'm not worried about it.
      11-04-2014, 08:23 AM   #12
G30 B58
Pace Car Driver
1547
It is plastic.
It's not a huge deal and a first world problem for sure. The fact that the water doesn't drain means that dirt and debris stays there too. If water pools there and it freezes then thaws slightly now you the possibility of a projectile flying off your car.
Again, first world problem but something I will eventually take care of.
      11-10-2014, 08:12 AM   #13
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Man just fill it up with something before wash like a foam sponge to suck this water then take it out after wash
      11-16-2014, 07:41 PM   #14
kingmonkey8
81
Drives: BMW 428i
Its the windscreen wipers holes for left and right hand cars. Can't believe they didn't mould some drainage channels or at least put some tubing to drain out the water. Poor design really. The car's got it's own pond.
You can't drill holes out either as there are some components underneath.
      11-17-2014, 10:07 AM   #15
Fast400
Fast400's Avatar
Germany
679
Drives: iX M60
2014 BMW  [0.00]
You can drill a small hole in the passenger side (I did it), just not the middle one (unconfirmed)
      06-21-2015, 01:55 PM   #16
Dgdoc
Anyone have an update on this?
Has BMW issued a TSB or changed the cowl to allow water to drain?
      06-22-2015, 05:42 PM   #17
G30 B58
Pace Car Driver
1547
I drilled a small hole in each. Did an M4 as well.
Sometimes it's the small things that make all the difference. Takes longer to put the bit in the chuck than to actually drill.
      06-25-2015, 03:14 PM   #18
Fast400
Fast400's Avatar
Germany
679
Drives: iX M60
2014 BMW  [0.00]
Where does the center one drain to underneath?
      07-01-2015, 04:01 PM   #19
435MSport6Speed
435MSport6Speed's Avatar
432
Drives: 435i M Sport 6 Speed
Noticed this Monday night during a wash. Bit of a surprise. You know they did water testing.
14 435i M Sport 6 speed, MG/Coral, MusicarNW Stage 3+ Upgrade for HK, M Brakes, MPPK, MPE, M Rear Spoiler, M Side Molding, full Expel wrap
      07-18-2015, 09:29 AM   #20
smithf80
smithf80's Avatar
2794
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
This sort of bothered me, it just seemed a little silly how much water can pool there, but it has never caused an issue so I've ignored it.
      09-28-2015, 02:55 PM   #21
Fast400
Fast400's Avatar
Germany
679
Drives: iX M60
2014 BMW  [0.00]
Looks like they've revised this for 2016. There's holes
      10-03-2015, 02:32 PM   #22
mdavis12
El Presidente
mdavis12's Avatar
16
Drives: 328i xdrive
a couple of years ago, when i took my car for service, i did notice a line item saying it was replaced. Maybe some dealers are aware of the issues, and are replacing it.
Search this Thread:
Advanced Search
f30post
