08-13-2014, 09:56 AM | #1 |
Rep 9
Spare Tire Solution
To anybody who is afraid of getting a flat on your run flats in the middle of the desert or anybody with non run flats (me) this is for you.
I've been doing heavy research on what people do with flats and this is the best I could come up with. http://www.bimmerfest.com/forums/sho...d.php?t=561806 Pieces to build a spare tire to fit our cars Since going to 20" wheels with nnon run flats, the thought of a flat is a scary thing. Even if I had run flats, my research shows bmw sos tends to suck, and especially if you're in the middle of nowhere on the weekend (which is when I take my road trips. Read some horror stories online. People taking planes home and leaving car, cars not getting new tires until Tuesday, 5 hour waits for a tow, etc) So get a spare! You never know what might happen. (or at least slime or a plug kit. My tires have road hazard warranty so I might as well just put the spare and get a free tire!) When oh when will bmw give us an option for a spare? ;( |
01-27-2019, 09:20 AM | #2 |
Rep 6
So has anyone successfully added a spare tire to your F34? How well does it fit under the rear storage floor panel? Are there inserts available for our body style? I've seen the F30 threads but I'd like to know how it would work with the F34. If I go this route eventually I'd like the spare to fit completely under the floor panel.
01-27-2019, 10:24 AM | #3 |
8233
Rep 16,069
I have one of these:
https://www.bavauto.com/bmw-spare-tire-b36000178 Despite being a compact spare it does not fit under the floor panel. For around town driving I don't bother carrying it. I toss it in the back when I'm taking a longer trip. |
Verminator0.00 |
01-27-2019, 11:33 AM | #4 | |
BMW CCA Member
488
Rep 808
Nice solution
Bimmerzone sells a similar kit but includes a jack and tools too for about $100 more. Smart buy all the way around. Run flats are great for nails and such, but tire shredding blowouts will leave you completely stranded. The other bonus, if you ever decide to run a "regular" performance tire, well you can run a regular performance tire and save about $400. |
01-27-2019, 11:48 AM | #5 |
8233
Rep 16,069
Another plus to the spare is that it you get a nail in your run flat you can change to the spare before you damage the sidewall of the run flat, so you don't have to buy a new tire. A few weeks ago a minute or two after leaving my garage I got a low pressure warning, showing one tire down to 7.5 PSI. I turned around and drove home. I pulled the wheel and took it into my basement to fix it, being too cold in the garage. I found and pulled out a nail, plugged the leak and put the wheel back on the car. It hasn't lost any pressure since then, and there are no sidewall bubbles. That saved me $180. Since this happened close to home I didn't use the spare, but if it had happened away from home I would have used the spare to get me home, rather than chance sidewall damage to the run flat.
Verminator0.00 |
