330i wont start?
08-11-2014, 05:31 PM | #1 |
51
Rep 605
330i wont start?
So yesterday I disconnected the battery to put a new relay in, I reconnected the battery and all was fine. I drove to get groceries and back with no problems. then today I went to drive to work and It just wouldnt turn over..? The battery is a year old from BMW. All the lights work. I am stuck, it wants to turn over but wont. I wasnt able to pull any codes either when I scanned it with the BAV tool.
any ideas? |
08-12-2014, 02:31 PM | #2 | |
34
Rep 471
08-12-2014, 02:35 PM | #3 |
Quiet till poked
99
Rep 1,176
08-12-2014, 03:43 PM | #6 |
60
Rep 675
If the IBS is not plugged or bad the car shouldn't have any power or I'm wrong? OP stated the lights work, can crank, just can't start. OP can you turn instruments on, go to hidden menu and see what voltage the car is reading?
08-12-2014, 03:55 PM | #7 | |
34
Rep 471
car just won't start when you push the button; mine is unplugged, if I plugged it back in, my car won't start either |
08-12-2014, 05:03 PM | #8 |
Beamer Mantic
82
Rep 1,191
Might be your starter, they don't always give you warnings!!!
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg Last edited by 3s4u2; 08-12-2014 at 05:13 PM.. |
08-13-2014, 08:10 PM | #10 |
17
Rep 328
What's your mileage? My 330i's starter went at 84k. It started with an occasional no start once or twice a month. Then it started doing it every morning. But the part was only about 160, and it was a whole lot easier than I imagined it was gonna be
08-13-2014, 08:44 PM | #11 |
Beamer Mantic
82
Rep 1,191
That is some excellent news, still could be your starter!
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
08-13-2014, 10:31 PM | #12 |
51
Rep 605
08-13-2014, 10:32 PM | #13 |
51
Rep 605
I am at 81K I heard the job isnt that easy so Im not sure if I can pull of a such a task.
08-14-2014, 01:25 AM | #14 |
1622
Rep 3,402
My starter lasted 197,000 miles (mostly highway so not a lot of starts I guess). Mine was a bit of a pain in the ass to change because I ended up having to change the entire oil breather system that had succumbed to the heat over those miles and became brittle. I ended up having to essentially redo the job because I forgot to plug in the tank vent valve sensor. It was much easier the second time. Hopefully there will not be a third.
08-14-2014, 02:28 AM | #15 | |
39
Rep 592
Starter is PAIN! I would never take that on myself. |
08-18-2014, 08:14 PM | #16 | ||
51
Rep 605
