R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      08-05-2014, 02:03 PM   #1
Ryan@IND
Ryan@IND's Avatar
1756
Drives: ACR
IND | European Sun Visor DIY
As BMW enthusiasts for nearly 2 decades it is no secret that our European counterparts are privy to some rather unique parts. Although a good portion of this is hometown support, some of these parts are simply a byproduct of regulation. The European visors are one of these products and offer a clean and cohesive look for the F8X interior. Gone is the blinding white, yellow, and black text staring you down in the morning. Below is a DIY guide for those looking to replace the unsightly visors.
These visors are available for purchase through our site. We will keep an eye on this thread for any questions, but we are also available via phone or email.
http://ind-distribution.com/ind/cate...-sun-visor-set
Email: info@ind-distribution.com
Phone: 866-963-4520 (Local 847-963-4520_
IMPORTANT! IND is not responsible for compliance. This is a European TUV approved product. Please check your state and federal motor vehicle compliance laws.
Tools required:
  • Torx 25
  • Nylon Prybar
Step 1:
Move sun visor to side allowing access to the mounting point. The visor is held in place by a single Torx25 screw as well as the PnP connector for the vanity light. Remove the plastic cover with a nylon prybar or interior trim tool.
Step 2:
Now that the Torx25 screw is visible simply remove this screw.
Step 3:
Carefully remove visor from the headliner. Upon removing the visor you will notice the PnP connector, disconnect this piece from the visor.
Step 4:
Reverse the installation and enjoy the clean European visors. No more glaring air bag logo.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      08-13-2014, 11:00 PM   #2
GregW / Oregon
Commander-In-Chief
2070
Drives: 2023 M2 Coupe, 2020 GLE 450
Visor label removal
On older ones the label could be taken off with heat, GoofOff and patience, but these look to be welded on?
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      08-14-2014, 10:54 AM   #3
Dundas
36
Drives: G82 xDrive BSM
I've removed mine without problem. I used 99% Isopropyl to soak them and finished up with Goo Gone to remove the glue residue. The only difference from previous vinyl visors was that because these have a rougher texture a little extra scrubbing was required to get all of the residue. I used an extra soft toothbrush for this.
'22 G82 xDrive BSM
'22 G80 xDrive BSM - Wife's
'15 F82 BSM - sold
'08 E92 M3 BSM - sold
'02 E46 M3 CB - sold
      08-14-2014, 10:55 AM   #4
Ryan@IND
Ryan@IND's Avatar
1756
Drives: ACR
Correct. BMW's attempt at a tamper proof design.
      08-14-2014, 10:58 AM   #5
Ryan@IND
Ryan@IND's Avatar
1756
Drives: ACR
Originally Posted by Dundas View Post
I've removed mine without problem. I used 99% Isopropyl to soak them and finished up with Goo Gone to remove the glue residue. The only difference from previous vinyl visors was that because these have a rougher texture so a little extra scrubbing was required to get all of the residue. I used an extra soft toothbrush for this.
Nice work, but I assume you still have the raised edge surrounding the area where the warning once was? I'm curious to see how this looks after removal
      08-14-2014, 11:13 AM   #6
Dundas
36
No raised edge but just like previously you can sometimes detect a slight change in sheen where the labels used to be. I don't think the current labels are any different than what I have seen before.
'22 G82 xDrive BSM
'15 F82 BSM - sold
      08-19-2014, 06:43 AM   #7
G30 B58
Pace Car Driver
1547
Drives: '22 AW G30 B58 M-Sport
I don't have my 435i yet but I'm wondering if these are a direct swap for the F32 as well.
      08-19-2014, 10:43 AM   #8
Nate@IND
BimmerPost Supporting Vendor
Nate@IND's Avatar
2863
Drives: BMW
The visors would be a direct swap and I have more Euro ones coming in this week from Germany
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      09-12-2014, 09:38 PM   #9
brian1225
15
Drives: 2015 F80 M3 MW/BLACK
I did the same. It was a cheap and quick fix.
2011 E92 M3 AW/Black Competition Package Fully loaded.
On Order 2015 F80 M3 MW/Black loaded minus ceramic brakes. Production start date: 07-08-14
      10-06-2014, 01:11 AM   #10
kinimod
134
Drives: 911 GT3
Is the only difference the sticker/disclaimer, or actually the visor has a different texture/material/feel?
The standard US one seems like rubber or plastic. Is the Euro version anthracite cloth?
      10-06-2014, 09:59 AM   #11
GregW / Oregon
Commander-In-Chief
2070
It appears from the OP the visor is the same material.
      12-25-2014, 02:58 AM   #12
2sporty
Germany
244
Drives: bmw
you can actually do this without taking the visors off. Just use isopropyl alcohol and a dish scrubbing sponge. It takes about 5 minutes per visor.
      12-27-2014, 03:34 PM   #13
GregW / Oregon
Commander-In-Chief
2070
Warning label removal
Just did the same - 91% isopropryl, let is soak for a while, then used a kitchen scrub sponge. Worked well.
      12-28-2014, 10:59 AM   #14
ipilcher
ipilcher's Avatar
385
Drives: 2024 M3 Compensation
Anyone have any more detail on where/how to pry open the mounting point cover?
      12-28-2014, 11:07 AM   #15
GregW / Oregon
Commander-In-Chief
2070
The cover is split, with the forward half hinged at the front. Pry at the split on each side and it will rotate down, exposing the Torx screw (see IND's 3rd & 6th photos).
      12-29-2014, 03:51 PM   #16
ipilcher
ipilcher's Avatar
385
Now that I've successfully done this, a few points for posterity ...
  • Pry the smaller part of the cover (the part that doesn't have the metal tube going through it).
  • A cell phone pry tool makes it much easier to pry the cover open without damaging it or the headliner. Auto trim pry bars are just too large.
  • Once the screw is out, rotate the visor/cover assembly to release it.
  • As usual, unplugging the electrical connections without damaging them is probably the most difficult part.
  • When re-installing, if the cover does not snap closed easily, tighten the screw farther. (It may take a fair bit of torque to do this.)
      12-29-2014, 09:51 PM   #17
GregW / Oregon
Commander-In-Chief
2070
Good additional points. A pry bar set like this is a good thing to have around and not very expensive:
      12-29-2014, 09:52 PM   #18
Mandi90TT
2712
Drives: BSM 6MT M4 F82
that's actually a really nice set. Where'd you get it?
2015 Black Sapphire Metallic 6MT M4
      12-29-2014, 09:55 PM   #19
GregW / Oregon
Commander-In-Chief
2070
Pry bar set
Just pulled that off the net, but I have a similar one in a different brand & color. Here's that one: http://www.carid.com/astro-pneumatic...-35961166.html.
      01-06-2015, 06:41 PM   #20
ipilcher
ipilcher's Avatar
385
Scotchgard?
Should I Scotchgard these?
I'll be replacing the plastic visors from my F34 with these, which has me thinking about the dirt, oil, etc. that may build up on the fabric over time.
Has anyone tried spraying something like this on these?
http://www.amazon.com/gp/product/B00...d_i=B00006IA8O
      01-06-2015, 10:49 PM   #21
GregW / Oregon
Commander-In-Chief
2070
The material is same as US visors, I believe; really more plastic than fabric. No protection needed, IMO.
      02-23-2015, 04:04 AM   #22
tiefergelegt
tiefergelegt's Avatar
Switzerland
29
Drives: M4
2014 BMW M4  [10.00]
I'm in Europe and I have this warning too. Only difference is, it's on the passenger seat's visor.. These visors without it must be some older stock or special production
Search this Thread:
Advanced Search
f80post
