Weak sound in front after upgrade
08-05-2014, 12:20 PM | #1 |
Rep 57
Hey all,
This is my 2nd post today about my system. I recently added some rainbow SLC 210 components to the front of my e92. I'm driving these with an xd600/6. Underseat, I have the sws-8 2ohm subs. I notice that the sound up front is not full. It's missing "body". Pardon me, I'm not an audiophile. When I fade to the back, the sound is full, when I fade to the front, the sound is weak and shitty - almost tinny, almost empty feeling. Any thoughts, or advice? If you need more info, please let me know. Thanks partypat |
08-05-2014, 01:47 PM | #4 |
28
Rep 609
Earthquakes might be the reason why.
There's plenty of posts here why the SWS aren't exactly ideal underseats. More than likely, you're missing a truck ton of music from the ~100-~300hz range. But yes, the point at where your sound is crossed over might be a big help. |
08-05-2014, 05:34 PM | #5 |
300
Rep 3,969
Please post amp crossover settings, and where are you getting the input signal?
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
08-05-2014, 05:44 PM | #6 |
281
Rep 4,121
08-06-2014, 08:52 AM | #7 |
Rep 57
Can you clarify what you need for 'where are you getting the input signal?' question?
I have a technic harness that routes into my xd600/6. Also, the xd600 has input gain, a hp/lp setting but no crossover setting. thanks Patrick |
08-06-2014, 09:07 AM | #8 | ||
2288
Rep 13,001
08-06-2014, 10:57 AM | #9 |
1911
Rep 13,104
Read the xd 600/6 manual
These settings are not for the speakers you have but are in the ballpark. Last edited by ctuna; 08-06-2014 at 11:05 AM.. |
08-06-2014, 11:00 AM | #10 |
Rep 57
HE HE, I got it now I am not an audiophile, I'm a guy with a computer and a car. HA! Both Ch 1&2 and Ch 3&4 are at HP 174Hz. Thoughts?
I saw filter frequency, that didn't mean the same thing as crossover in my mind. Thanks! |
08-06-2014, 11:20 AM | #11 |
28
Rep 609
Am I reading that right? You're letting anything from 174hz through to your tweeters and mids?
I mean, this isn't the reason, but wouldn't you want the mids to be highpassed around 300hz? tweeters highpassed around 4000hz? That just looks like risking your tweeters and mids getting blown... The thought I think everyone might be driving at, is are you sure that you don't have that switch setting to Low Pass by accident? Thereby only sending low frequencies to the tweeters and mids (that they can't play?) |
08-06-2014, 11:30 AM | #12 | |
Rep 57
08-06-2014, 12:19 PM | #13 |
281
Rep 4,121
I don't know what channels are going where....but:
Ensure your Front Mids & Tweets are HP Underseat are LP Rears are HP Technic can comment on the input channel mode for whichever harness version he sold you. and again, make sure your passive crossovers are wired correctly. |
08-06-2014, 01:46 PM | #14 | |
Rep 57
Thanks |
08-06-2014, 05:43 PM | #15 |
281
Rep 4,121
Hmm, everything sounds ok by your description...
Try a straight 200hz HP/LP on everything. Ok to have some extra gain up front. check your switches to make sure they are properly seated in the HP/LP as appropriate. |
08-06-2014, 06:09 PM | #16 |
28
Rep 609
Just to be sure...
In Ctuna's pic, I see the proper wires leading out of channels 1-6... In partypat's pic, I see no wires leading out of those spots. Did you disconnect everything before taking that picture? |
08-06-2014, 11:32 PM | #17 |
1911
Rep 13,104
How are your door components set up?
Did you get and install the passive crossover that comes with most all component sets. They usually have a jumper to balance the gain between the tweeters and 4 inchers and as a rule they need to be set to the neutral or negative position. Mine are set to -3db. The front door speakers should be able to take some gain . Also with the fronts I would set the crossover on the amp higher I would try around 200 hz to start with . Last edited by ctuna; 08-06-2014 at 11:40 PM.. |
08-09-2014, 02:12 PM | #18 |
Rep 1
Frequency gap
Just curious. Why is there a gap between your LP frequency and your HP frequencies? Shouldn't the HP pick up at least as low as the frequency where the LP left off? I understand that might not be the case for the rear channels if they aren't getting a full range signal.
08-09-2014, 04:51 PM | #19 | |
Rep 57
thank you.. my crossovers are fully sealed no jumpers.
08-09-2014, 05:54 PM | #20 |
Rep 145
pat,
This really does sound like a cross-over problem to me. Do you have the "round" passive x/o's with those Rainbow components? The reason I ask is because I believe those can be bi-amped, meaning that it is easy to hook them up incorrectly. Also, I thought those did have multiple variable attenuation settings for the tweeter on them. |
08-09-2014, 06:51 PM | #21 |
tends to get irritable
202
Rep 798
If you have no jumpers then I suspect your problem is Very likely in the install or the lack of the right crossovers.
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
08-09-2014, 06:52 PM | #22 |
202
Rep 798
They do. There's a lot of flexibility in them.
