The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Has anyone had their JB4 reset while they're driving?
      08-04-2014, 02:45 PM   #1
mashimarho
BimmerPost Supporting Vendor
mashimarho's Avatar
2111
Drives: E92 M3 & F80 M3 & G82 M4
I have it set so the needle gauge sweeps when I start the car. I'll be on map 2 or something, and while I'm driving, the need gauge will sweep while I'm going down on the highway..
Usually when it does that, the car will also jitter. It doesn't happen often, but maybe once every few months. I usually reset the JB4 back to map 0 or restart the car, and it's fine...
All connections fine, yada yada yada
Mashimarho.com /// Instagram /// Facebook /// Youtube /// sales@mashimarho.com /// (425) 582-7939
      08-04-2014, 03:18 PM   #2
Jsoboti
Jsoboti's Avatar
28
Drives: 2011 335i E92 M-Sport 6MT
I haven't had it happen like this but I've had the gauges sweep maybe 30-40 seconds after starting the car, kind of weird. Also if I'm at idle and I enter the Jb4 menus the car shutters for a second then runs fine
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
      08-04-2014, 04:24 PM   #3
mashimarho
mashimarho's Avatar
2111
someone similar to mine, yes.. Still no idea what the cause is.
      08-06-2014, 07:24 PM   #4
MUFASA1
MUFASA1's Avatar
Drives: 2011 335i Mineral White Metall
This might be difft from your issue but mine kept resetting itself on install hence I removed it coz I got scared it might happen while driving
      08-10-2014, 06:46 PM   #5
snaimpally
136
Drives: 2011 335i MT
2011 BMW 335i  [0.00]
I don't have the gauge sweep enabled but have not had any issues with the JB4. The gauge sweep is set to only happen on startup so if it is happening while driving the car, something is causing the JB4 to think the car was started/re-started. I'd double check the CAN wire connections.
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200
      08-19-2014, 11:09 AM   #6
johnson47376
johnson47376's Avatar
33
Drives: 2011 335i e92 ///M
I had this happen to me as well, but I had the "warm engine option" enabled where the signals crash twice. I'd be driving and they'd flash and then car would jitter. It hasn't happened to be either in a few months and never did figure out the issue. I checked connections and never found anything out of place.
2011 E92 335i ///M Sport in SGM/ 19" Forgestar CF5V/
Pure Stg2 Turbo/ Pure inlet/ GFB DV /Fuel-it Stg2 LPFP/BMS intake/ JB4 ISO BMS BEF/AR Design DP/ ER CP/Wagner FMIC/ Wavetrac LSD/BMW PE/ KW Street Comfort / MusicarNW Level Two Audio Upgrade/CDV delete/3000K HID Fogs/ N20 plugs/ JB4 BT Rev3
      08-27-2014, 03:32 PM   #7
I35it
all day
I35it's Avatar
48
Drives: 2012 135i
2004 Toyota Tacoma  [0.00]
2009 VW GTI  [0.00]
2012 135i  [10.00]
also happens to me. Very interested to see what causes this.
      08-27-2014, 05:29 PM   #8
jwzimm
jwzimm's Avatar
687
Drives: '16 M3
Check your installation. Perhaps your power tap for the JB4 is loose...?
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!!
2011 e92 X-Drive Coupe - SOLD!!
      08-28-2014, 07:52 AM   #9
mashimarho
mashimarho's Avatar
2111
Shouldn't be. I've checked connectors. I've had the unit for about 2.5 years now without issues. Once in a while it will happen even on start up. It's not frequent, but enough to annoy me.
      08-28-2014, 11:56 AM   #10
hetzle
hetzle's Avatar
32
Drives: E90 335i
I used to have that happen intermittently before I had my installation fixed, the wires are now soldered in place and I've yet to experience it since.
2011 335i sedan 6MT, 515whp/530wtq. Pure Turbo Stage 2, Motiv SST TwinDisk Clutch/FW, Motiv Flash, AA 4" DP, ER FMIC, AA turbo-back exhaust, Quaife LSD, ST Coilovers, BMS Intake, UUC DSSR+SSK, ER CP, BMS CDV, BMS OCC, Arkym CF trunk
      08-28-2014, 12:28 PM   #11
mashimarho
mashimarho's Avatar
2111
Hm. Maybe I have to check up and get it soldered....
      08-28-2014, 01:13 PM   #12
wwc310
wwc310's Avatar
52
Drives: e92 LCI 335i
I had it happen one day as well. turned off the car, turned it back on and haven't had any issues in over 6months
Edit: My jb4 acted funny last night 8/28/14. Restarted the car and it went away. Merged onto the freeway and my chargepipe blew.
2011 335i e92
JB4 Stage 2, VRSF chargepipe, VRSF downpipe, Hankook Ventus V12 evo2s
      08-27-2016, 09:55 AM   #13
Owens84qv
Drives: 2011 335xi, Ferrari 308QV
Resurrecting an OLD thread. Running map 1 and have had JB4 reset itself several times over last past couple of days. Checked power (reseated power), checked and moved ground. First test and JB4 appears to have reset itself again after running a few minutes.
Could it be the board?
Welcome to any ideas.
Terry...thoughts?
      08-27-2016, 12:38 PM   #14
Chris_Rav
Chris_Rav's Avatar
64
Drives: 2011 e92 LCI 335i xdrive 6MT
My JB4 was doing something similar. My issues started with the gauge sweep happening randomly as I was driving, never really bothered me too much. Then my car started to do the sweep and it started stuttering on accelartion kind of like a misfire, the gauges would go crazy at this point. The needles would continue sweeping or one would get stuck somewhere along the way, if i tried to turn off the tune it would freeze up and leave me with just the orange screen and the needles stuck until I restarted the car. It got so bad that i was driving the car for a few weeks without the tune even being on.
A few days ago I cleaned the CAN wires really good and reinstalled them and since then I've had no problems and the car runs perfectly fine. Try cleaning the CAN wires and checking to make sure all your sensors are in tight.
2011 AW / CR 6MT 335i Xdrive Coupe | JB4 Stage 2 | BMS Intake | Performance Spoiler | Powder Coated Red Linea Corse 818 | Blacked Out Roof | Wrapped Interior Trim
      08-27-2016, 03:46 PM   #15
orteeze
223
Drives: 2018 YMB F80
Chris_rav makes a good point. The CAN wires have a funky residue from the insulator/heat shrink they use at the factory.
      08-27-2016, 10:54 PM   #16
Owens84qv
Exactly the same symptoms as mine...exactly. I'll clean the CAN wires tomorrow. This is my 2nd 335, both of which have had JB4's. On car #1, I installed and when I did, I made sure the CAN wires were surgically clean. I inherited this install (2nd 335) so, troubleshooting something I didn't install.
      08-28-2016, 12:12 PM   #17
sd306
sd306's Avatar
381
Drives: X5 40i
I'd cut the wires back to remove any residue then strip and solder them in to eliminate that possibility. I only cleaned mine with alcohol and twisted them within the other wires (untwisted those first.)
Are you on ISO 5.11?
X5 40i
      08-28-2016, 12:23 PM   #18
Owens84qv
i cleaned the CAN wire extremely well, applied electrical tape, heat shrink, etc. I pulled the clear plastic 'boot' off and there was a fair amount of residue so we'll see if that works. Stupid question...how do I check ISO version?
      08-28-2016, 07:50 PM   #19
sd306
sd306's Avatar
381
Drives: X5 40i
You have n55 jb4 stage 2?
How do you check logs? Usb or bluetooth?
If your not running ISO you should. There is the stock jb4 that runs an older firmware then there is ISO that requires cutting a diode on the board and flashing with ISO firmware.
X5 40i
      08-28-2016, 08:05 PM   #20
Owens84qv
I'm running the G5 board, which from what I know, is running ISO.
      08-28-2016, 08:13 PM   #21
sd306
sd306's Avatar
381
Drives: X5 40i
Update the firmware too, check all connections since you didn't install it.
X5 40i
      08-31-2016, 10:05 PM   #22
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
I had my JB4 go mental for a while.
If you have the extension harness it can be dodgy, I had mine cut off and hard wired back in.
Also in general the JB4 harness is poor quality, replacing it might help.
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP /
