08-04-2014, 12:50 PM | #1 |
BimmerPost Supporting Vendor
8113
Rep 18,802
Drives: BMW
M3 JB4 Beta Testing: 491whp/531ft-lbs
Wanted to post results from JB4 testing over the weekend on forum member tightie's M3 with some pretty impressive results. While here, we also removed the charcoal liners and installed a set of K&N Filters.
This is only the beginning, we're about to see some exciting stuff in the upcoming weeks. Vehicle: 2015 BMW M3 Modifications: Gintani DownPipes (catless), K&N Filters, JB4 Fuel: 91/E20 STD SAE Conditions And yes, that is a M1 in the background
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 08-04-2014 at 02:30 PM.. |
08-04-2014, 01:00 PM | #3 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
Thanks Tom/Steve/ Everyone at EAS! You guys rock.
Can't wait to come back with some higher octane. If anyone was wondering, 3.25 Gallons of E85 and the rest 91. It is basically a 93 RON.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
08-04-2014, 01:01 PM | #4 |
10802
Rep 27,595
heck yea!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
08-04-2014, 01:13 PM | #6 |
1692
Rep 3,200
Crazy!!!
08-04-2014, 01:19 PM | #7 |
8113
Rep 18,802
Drives: BMW
Too minimal of a change to be accurately caught on the dyno. Just get those things out as its restricting airflow.
08-04-2014, 02:19 PM | #9 |
846
Rep 3,249
These numbers look great! I might have to keep my EC-7s if that's what they'll look like, lol.
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold '18 /// M3 - Individual Imola/Black - Sold '15 /// M4 - YMB/SO - Sold '12 E92 ///M3 ZCP - AW/FR - Sold |
08-04-2014, 02:29 PM | #10 |
590
Rep 5,396
That second calibration looks very good. In 100* heat no less
Smooth curve and holds power well. Seems the dp allow for holding power to redline. Nice work already! |
08-04-2014, 02:34 PM | #11 |
8113
Rep 18,802
Drives: BMW
Updated charts with later run with FUA 40 run, which eliminated the boost spike and allowed a bit more adaptation to take place.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 08-04-2014 at 02:55 PM.. |
08-04-2014, 02:42 PM | #12 |
Joint Chiefs of Staff
4912
Rep 115,980
Charts look great. Exactly how map 1 should look. 40-50whp over stock. AFR is spot on also for a direct injection motor.
Map 1 doesn't change the air/fuel ratio directly. Instead it lets the DME run it. On race gas, E85, or under conditions that allow for less knock activity, it will lean the mixture out. On pump gas, higher EGT, during sustained runs, etc, where there is the potential for more knock activity it will enrich the mixture. It's a very dynamic and effective system. One nice thing is with the JB4 is if you are interested you can directly monitor knock, afr, etc, when logging (via laptop, iphone, android, etc) and see the DME in action. The JB4 also monitors the data and has criteria for safety disables. If the fuel pressure gets too low, AFR goes too lean, boost goes too high, knock goes too high, etc, the JB4 will disable itself. Mike |
08-04-2014, 02:46 PM | #14 | |
249
Rep 2,202
Mike I'm just getting ready to start on my m4... How would I do it via iPhone? Car is running great with just the stock map1 by the way for all those wondering.... Install was easy MAP sensor was a little bit lame but at least you can see where it needs to go unlike the M5 where it was all in the feel. Last edited by M5Rlz; 08-04-2014 at 02:52 PM.. |
08-04-2014, 02:55 PM | #15 |
1110
Rep 3,262
How much is involved to install the JB4?
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
08-04-2014, 02:59 PM | #16 |
2133
Rep 5,011
08-04-2014, 03:02 PM | #17 |
249
Rep 2,202
TMAP is legit right next to the intake[right side, also across from it sit the CAN access points to install those stage 2 wires if one wants and appears to be more time consuming]... The reservoir at the top middle of the engine right below it sits the map sensor thats a tad tricky... No more than an hr to get the stage 1 going. 15 minutes if you've got skilled hands.
08-04-2014, 03:05 PM | #18 | |
8113
Rep 18,802
Drives: BMW
We go over the airbox portion here in the BMC filter install thread: http://f80.bimmerpost.com/forums/sho....php?t=1014235. Once the box is removed, the solenoids are easy to spot. Everything else is easily accessible.
08-04-2014, 03:32 PM | #21 |
4912
Rep 115,980
http://www.n54tech.com/forums/showthread.php?t=21742 Mike |
08-04-2014, 04:19 PM | #22 |
42
Rep 186
Thanks for posting SAE, been wanting to see the difference. How much power did the down pipes add? I'm thinking of using the tune only so I wanted to estimate that alone.
